diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Solid State (http://www.diyaudio.com/forums/solid-state/)
-   -   Amps to drive Quad esl 63's (http://www.diyaudio.com/forums/solid-state/102163-amps-drive-quad-esl-63s.html)
Crim 19th May 2007 02:46 PM
I am a new member and not an expert, hence my question to the forum.
I have a pair of Quad esl 63's, purchased last year and they seem to work well with the Naim Nait 2 that I purchased new in the early 90's.
However, I recently considered upgrading to a seperate Naim power amp and using my Nait as a pre-amp and was then introduced to an amp that I had not hear of: Electrompaniet NSD 'The 2 Channel amplifier' and this was suggested as a good match with the Quads using the Nait as a preamp. I have read a litle of its history and development but have no idea what it would sound like.
Does anyone have any thoughts: better to stick with a Naim power amp?
jacco vermeulen 19th May 2007 05:35 PM
I favor a couple of others on this list more than the Naim or the EC.
30 and 25 watts are a bit thin for the ESL63.
amp list
(the only one from the first 3 columns i haven't heard with ESL63s are the New York and the Nak amp)
sandyK 20th May 2007 05:54 AM
I may be very wrong about this, but I vaguely remember reading that when driving Quad ESLs, that the amplifier used should be stable into high capacitance loads.
Perhaps some other forum members can shed further light on this ?
Sandyk
nate 20th May 2007 06:38 AM
Yes your are correct. The quads are a somewhat higher capacitive load than "average".
The Electrocompaniet would probably be fine, but if you like the naim sound go all the way with naim- don't mix and match. The 63's are really incredible speakers but they really need 50 tube watts or more solid state to get them performing their best. I spent many blissful hours with a pair of 988s and a Conrad Johnson MV-60 which is a 45watt EL-34 based amp.
nate
Resources saved on this page: MySQL 18.75%
