what is the main diference beetwen amp that uses only n channel output stage or amp that uses n channel and p channel transistors?
#2 |
N channel or N + P channel ... Aussieamplifiers.com has recently introduced their newer versions of their N + P channel MOSFET amps ... The newer ones are all N Channel.
http://aussieamplifiers.com/nx150.htm ... to this: ... http://aussieamplifiers.com/nx150s.htm ... and their slightly older high power amps are all N Channel ( http://aussieamplifiers.com/nx500ln.htm and http://aussieamplifiers.com/nx1000ln.htm ) I can't tell the difference, listening test wise, but there are small differences when viewed on a 'scope = lower noise threshold & PS noise rejection, etc., so there must be something to it ... I do know that either type sounds very, very nice indeed. On similar subjects: http://aussieamplifiers.com/lateral.htm
Over compression is a problem with modern CD recordings |
| Creating 5.1 Multi Channel sound from 2 channel | jenkrich | Everything Else | 5 | 1st September 2009 07:29 AM |
| 4 channel conversion to mono 1 channel | iUSERTLO72p | Car Audio | 24 | 25th October 2007 05:07 PM |
| HELP!: Channel volume very very low, other channel fine. | harrisni | Solid State | 2 | 20th September 2006 11:10 AM |
| My 4 channel car Amp distorting on 1 channel (large pics) | MikeHunt79 | Car Audio | 9 | 3rd September 2003 06:41 AM |
| Help quick! 4 Channel > 2 Channel? | zmoz | Car Audio | 3 | 5th July 2003 08:48 PM |
| Page generated in 0.07101 seconds (70.32% PHP - 29.68% MySQL) with 10 queries |
