I am building my first preamp after successfully building Peter's LM3875 Chip amp. I have bought circuit boards from Elliot Sound Productions in Australia. My preamp will consist of:
- Signal selection - phono stage (separate pcb) - preamp pcb - volume potentiometer - 3 band eq (with adjustable mid q and bypass-able, this will be p2p wiring) My question is thus: Can I use my ESP +- 15V power supply to power the preamp, phono stage, and eq stage? I suspect I can ... but I'd like more info. here's a link to info on the psu board I'm building. hxxp://sound.westhost.com/project05a.htm ... and the preamp ... hxxp://sound.westhost.com/project88.htm ... and the phono stage ... hxxp://sound.westhost.com/project06.htm Thanks everybody! |
#2 |
Yes you can do this. Return all power connections directly to the PSU board, don't daisy-chain boards together.
You might want to add some small heatsinks to the regulators on the PSU, if the regulators get too hot. Try it without first and touch them. If they are getting too warm (you can't hold onto them for a few seconds without it hurting) then add heatsinks. |
#3 |
When regulators are in the middle of a circuit board, applying heat sink is tricky...
In this case I solder the regs on the underside of the board (the copper side), fold the legs, and screw them on the chassis metal plate on which the PCB is mounted. Works well on aluminum plates, but not on steel. (watch the pinout though, don't solder them with reversed pinout...) |
#4 |
True, however it looks like Rod has allowed space for some small heatsinks to be fitted. It's not ideal as the regulator pins would be supporting the heatsinks, but it would be OK.
#5 |
thanks guys, that's exactly what I wanted to know
| Multiple subwoofer/multiple amp question | boogs | Subwoofers | 5 | 13th November 2007 04:36 AM |
| multiple op's amp | adason | Solid State | 3 | 2nd June 2005 09:04 PM |
| Using multiple (like 40) TL074s... | Stocker | Chip Amps | 39 | 19th December 2004 01:50 PM |
| Multiple projects | Klax | Tubes / Valves | 11 | 2nd July 2004 05:28 PM |
| Ground connections across multiple components | Saurav | Everything Else | 4 | 18th September 2003 10:14 PM |
| Page generated in 0.07629 seconds (84.32% PHP - 15.68% MySQL) with 10 queries |
