protect light is on can you help?
Old 16th May 2007, 08:13 AM   #1
lilchriscustoms is offline lilchriscustoms  United States
Default protect light is on can you help?
I have a Kenwood 923 2ch amp and a crunch 3004 4ch amp and they both have the protect light on i looked inside everything looks fine (no burns no caps blown apart i don't know) everything looks fine can someone help me i also have punch 150 old school that 1ch works fine and the other is distorted i opened it and one cap is blow apart so i think i have to replace that wright? thanks for the help......Chris
Old 16th May 2007, 10:14 AM   #2
djk is offline djk
djk's Avatar
The Punch 150 with the blown cap probably has a blown fuse and/or output on the same channel.
If you mess with taking an output off, be careful. If you scratch the heatsink then you have to add insulators.
Candidates for the Darwin Award should not read this author.
Old 17th May 2007, 06:24 AM   #3
gmphadte is offline gmphadte  India
Have u powered them after long or from storage.
Old 18th May 2007, 01:44 AM   #4
yes just the other day
Old 18th May 2007, 09:53 AM   #5
U have powered the unit after long storage, then...
u have to physically inspect the unit(s) for any bugs' outputs(liquid or solids) on the pcbs. These tend to conduct and the circuits will misbehave. The tracks will corrode and open. Check for green corrosion on the tracks.
If the storage was at considerably higher humidity levels/place, then u have to use a hot air blower and heat the pcbs with the power chord disconnected. Wait for it to cool down and then test.
Electrolytic capacitors on long storage tend to dry and fail on sudden power-up. U couldn't have avoided this anyhow.
Gajanan Phadte
protect light is on can you help?Hide this!Advertise here!
speaker protect norstar815 Solid State 4 1st June 2008 05:40 AM
Protect light on.. i cannot get it to work Snookumsthacat Car Audio 1 27th June 2007 04:04 AM
amp goes to protect, why? eeyore757 Subwoofers 6 22nd March 2007 12:29 AM
protect your amps skyraider Tubes / Valves 20 9th October 2004 09:39 PM
Copyright ©1999-2017 diyAudio
