After the lone ranger episode
so we will look the original aussie PSU
there are two size caps in there use
10000uf 100v and 6800uf 63v
you can look the picture direct to aussie site
http://www.aussieamplifiers.com/index3.htm
This PSU use Jamicon 10000uf 100V looks cool
because i will use Elna 10000 uf 63V what will
happen ?
I pray for better sound quality, Of course
If not change to BG FK ... of course not !
do not have more budget anymore
happen ?
Banned
Joined 2002
jeffry_widjaja said:After the lone ranger episode
happen ?
What are your rail voltages going to be ? This will help to know, if they are 70V as recomended for the amplifier then id stick with 100V cap's But if they are going to be around 50V then 63 will be fine.
Jase
" ... What are your rail voltages going to be ? ... 70V as recomended for the amplifier then id stick with 100V cap's ..."
Absolutely correct. These capacitor manufacturers know what they are doing and when the say 63 volts rating, they mean that 64 volts or more has a very good chance of causing a failure ... zzzzztttttt ... smoke, smoke, stink ...
45 Volt
My rail voltages will be 45 Volt so i use 63V caps
There an instalatur in Indonesia here say
Its ok too if you use 100uf 50v caps and you change to
100uf 100v, it will bring you high quality
and why people dont doit cause it is expensive
Is that right ? Bring you better quality ?
I answer " cool, maybe i do it someday "
maybe he got short too
If you search for 100uf 35v and they not available maybe
you can change to 100uf 50v or 47uf 50v but bigger twice
the caps voltage, i dont know really
This is the picture with Nichicon FW 6800uf 63V
Banned
Joined 2002
Re: TITANIC
Maybe, but not likely. I doubt you will hear the difference.
jeffry_widjaja said:When i take this picture, i say "Looks like Titanic"
and wheres is Leonardo ? Ha .. Ha ..
I think this is better than the other one
More weight, bigger and hope more performance
So Lets Go TITANIC
Tuuuiiiittttt !!! Duuutttttt ... Duuutttttt !!!
Banned
Joined 2002
si_jopie0382 said:Maybe, but not likely. I doubt you will hear the difference.
i hope more open than nichicon
give me your experience jleman
so no need to wait until it finish
about "snap in" caps
will we need to solder this caps too after
it is snap in pcb ?
Every thing has to be soldered
Detail Info
Maybe if anybody read about this thread will think
this is easy or maybe this is promotion or something
but it is not like that
This thread i make to support this
http://www.totemacoustic.com/english/products/floorStanding_forest.htm
Totem speaker known as power hungry
so i push this NX 150 to support as best as he can
This my Totem Forest Picture
They wait to powered
They take a rest for a while
Look the difference
This is picture of NX 400
The new creation of Father Anthony
( Like Father in "GODFATHER" )
There a little difference here ..... hmmm
If i not wrong that must be Elna Cerafine
If you look in other picture theres 100uf 100v
Maybe i little bit naughty too
what will happen if we playing with the caps
hmmm ... will i shoot by anthony !
I think not because he must use Missile
from Tazmania to Jakarta
So why dont we try something
Maybe we can know what is secret in there
Maybe i must change the tittle from
"Aussieamplifiers NX 150 Spider" to the new one
"Fear Factor NX 150"
It look brave same with the music i hear now "SWAY"
Banned
Joined 2002
Re: Look the difference
The difference between these 2 amplifier boards that you have posted pictures of are, better components = better sound. Cheap compnent's wont unleash the missile you are looking for
My theory, buy the best you can and roll with that. The class a Mini Alephs i run are 20watts and to this day i still don't use the full amount of power they have.
Jase
jeffry_widjaja said:After talking others thing lets go back
to talk about nx150 synergy
lets look for original picture which post
in aussieamplifiers website
(No need take those picture myself )
jeffry_widjaja said:This is picture of NX 400
Jase
- AussieAmplifiers NX150 Spyder
