Well, I think I overdone it with my 'speaker party'
The SM-80 is responsible for the bass in my speakers, and it seemed to have got a little too hot for it's output. The output as such is fine, but : - it takes quite a time to come 'online' - there are scratching noises, which become louder- not the whole time, but every now and then- and (as far as I can hear) only at the right channel It looks like the small electronic board at the front has become too hot, at least as I can see from the underside of the board. I replaced all the capacitors there, with no luck. The soldering points of the main transistors on that board look worst, but it seems it's not that easy to find these. I also re-soldered the whole board, with still no luck. Maybe I'm lucky again and someone knows this phenomenon... Thanks a lot in advance, Chris |
#2 |
You've probably blown one or more output transistors. You need to check them, also check the DC offset at the output. Is there a protection relay? Does it take a while for that to click on?
#3 |
mmh, that wouldn't be nice
![]() Yes, the protection turns off very late (being in IT that's what I meant with 'becoming online' can I test the transistors with a normal multimeter, too (transistor test, inductivity and capacity) or would I need a osci for that (which I don't have)? what approximately should the DC offset be? Sorry for the probably dumb questions, but apart from soldering and electronic basics I'm pretty hopeless in electronics... Thanks in advance, Chris |
| Denon AVR 1804 - popping / scratching / noisy | nazdackster | Solid State | 7 | 22nd March 2008 11:08 PM |
| Speaker midwoofer scratching! please help! | Toast_Master | Multi-Way | 10 | 25th September 2007 12:53 AM |
| yamaha amp scratching sound | ihodiputah_510 | Solid State | 2 | 22nd April 2006 09:43 AM |
| Scratching noise on Maroon5 | JohanH | Music | 11 | 8th January 2006 02:57 PM |
| QUAD ESL 63 noises | tabaregg | Planars & Exotics | 2 | 15th December 2004 11:28 PM |
| Page generated in 0.06777 seconds (70.14% PHP - 29.86% MySQL) with 10 queries |
