I found this "Electronic Tweak" on the www.tweakaudio.com website.
4.Get rid of all LEDs. They add noise to the power suppliesand mess with imaging and purity,neon lamps or such for indicators.,if needed.Power indicators do what ? How do you know when something is on....it plays....don't need no stinkin LEDs. Is this guy for real ? I use a blue LED as a voltage reference for the VAS in my Class A amplifier instead of a noisy 3.3V zener diode, and my amplifier is dead quiet. SandyK |
#2 |
I have heard this roumor too...
I also rememember a thread showing how a normal led could be used as a button, as it is sensitive to light also... think it produces a small voltage...(typeing under correction)... If this is enough to affect sound, is something we need to ask the guys with the scopes... |
#3 | |
Electrons are yellow and more is better!
/Per-Anders (my first name) or P-A as my friends call me |
#4 |
I know that some types of LEDs can be used as photo detector diode of sorts. I find it very difficult to believe that a LED , when passing a current of several mA, will respond to external stimulus at any meaningful level. In the case of a LED panel indicator,so what ? It would have to emit a lot of rubbish to affect anything inside a metal case (or plastic!) I always understood that a conducting LED (using DC) was very quiet
Am I wrong in using a blue LED as a voltage reference? I have seen numerous circuits from Elektor , and others, that use red LEDs for voltage references. SandyK |
#5 | |
#6 |
Among the many unfounded claims I found at that website, this looks like a very obvious one.
These are the spikes generated by a neon lamp in close proximity of the scope probe, not connected to the circuit. Try that with a LED. /Hugo |
#7 |
I feel sure that most members would be well aware of the noise from neons,to say nothing of the flickering. A couple of my nice green bezelled rocker switches use neons, and none of them still work. How many extension power
boards have neons that don't flicker , or for that matter still work ? I did a quick "Google" for "light emitting diode noise" and was unable to find any reference to their noise generation, only noise generated by their control circuitry, as in traffic lights etc. On the contrary, LEDs seem to be used a lot in noise detection equipment ! SandyK |
#8 |
There was a thread here a year or so ago where someone actually measured the noise from LEDs, and IIRC, it was insignificant.
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#9 | ||
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#10 |
Good reply S.Y... very usefull...
I suppose what kills neons, is the HV spikes they experience several times a day...unlike X and Y caps they are not designed for this and have no selfrepair feature... What are some of the benefits you alude to? |
| What makes an amplifier "bright", "warm", or "neutral"? | JohnS | Solid State | 51 | 13th December 2009 06:42 PM |
| What Does Fostex "Rated Input" and "Music Power" | mark02131 | Full Range | 3 | 2nd January 2007 08:31 PM |
| Fostex "rated input" and "music power" | hugz | Full Range | 12 | 16th March 2006 04:33 PM |
| Some final pics of "Stacks" revisited and "Askew" with stand | Andy G | Multi-Way | 2 | 3rd February 2005 06:07 AM |
| Anyone used Scan-Speak's "Flow Resistors" or "Aperiodic Vents"? | Ignite | Multi-Way | 3 | 18th November 2001 08:42 AM |
| Page generated in 0.13400 seconds (78.58% PHP - 21.42% MySQL) with 11 queries |
