#51 |
MikeB, you are correct! I accidently used the 100ms line with that part, and it is comparable to the bipolars that we use, but do look at the IRF's Very bad, still.
We do use the 2SK1530-J201 pair for the output driver devices to drive the bipolars in the JC-1 power amp. |
#52 |
Hi John, yes, the IRFs are not too impressive here... But the Toshiba mosfets are ! (Not to forget, the Toshibas are intended for power amps, the irfs are typically for switching)
Mike |
#53 | |
John, Thanks for this detailed answer. I agree, when MOSFETs go, for whatever reason, they go fast. Hey, I've blown up a lot of them! My experience has been that they will usually not outlast a fuse; they definitely need some sort of last-resort protection against short circuits, such as an electronic crowbar. In some respects, in a short circuit condition, they may be their own worst enemy, since they will readily each attempt to deliver 50 amps or more; there is not much of a mitigating mechanism to reduce such high current flowing in the presence of a sudden short. I don't know how much of a role it mught play, but high-current beta degradation in bipolars might be an example of such a mitigating factor (as long as the driver transistor survives - in this sense, your choice of MOSFETs as drivers makes sense). As far as device destruction goes, sometimes it is a chicken-egg situation, and it is hard to tell what the initial proximate cause of the destruction was. For example, often in conventional output stages the driver will die with the output transistor, and one doesn't always know which one went first. Another way in which MOSFETs will go very fast (fast devices blow faster?) is if for any reason the oxide is punctured. For example, in the case of a short circuit, if the driver successfully applies more than 20V forward bias to the MOSFET gate, poof!! That wasn't the fault of the MOSFET, but rather an ill-controlled driver. Similarly, if the application of the short circuit causes operating points or circuit parameters to shift enough to cause the MOSFET to go into a parasitic oscillation at 100 MHz, poof!! All I'm saying here is that we don't always know that the cause of the destruction was the die temperature getting up to beyond, say, 175C. The p-channel devices are usually inferior to the n-channel devices, but what specifically do you especially not like about the IRF p-channel MOSFETs? Here's a trivia question for you that I honestly don't know the answer to. Which came first, the HEXFET or the ring emitter transistor? Both were born of the same essential idea: use integrated circuit-like technology to effectively build a transistor that consists of hundreds or thousands or tens of thousands of little transistors in parallel. I'm still interested in learning what your favorite difficult load is for evaluating your amplifiers, and what general type of output stage protection circuit you use. Bob |
#54 | |
Account Disabled
#55 | |
The one and only
ring emitters in 1977. |
#56 | |
Nice web site. Thanks for pointing this out. I too really like LTSPICE. Bob |
#57 | |
Mike, There is nothing wrong with the skillset of most of the people here. I continue to be impressed by everyone's intelligence. And there is nothing wrong with intelligent, well-intentioned people disagreeing. Indeed, I have always asserted that what influences an EE's design the most is what he or she FEARS the most. This is certainly the case with me, and most of the engineers I work with agree with this observation. So it is not so much skillset, or intelligence or even diligence. It has a lot to do with experience with a particular thing. We pick our poison. We find our comfort zone. Anyway, can you elaborate on why you think that MOSFETs are inferior to modern BJTs in audio frequency applications? We ALL learn from these lively discussions. Thanks, Bob |
#58 | |
Chris, I agree, there are a PLETHORA of really bad MOSFET designs out there. As is often the case with any "new" technology there are those numb-nuts who ignornatly exploit it because it is the latest buzz-word (digital, anyone?). There are also those ignoramuses (sp?) who see that the beta of a MOSFET is infinite and think that they therefore can make a good amplifier without using a driver stage between the VAS and the output MOSFETs. Bipolar transistors suffered from these same sorts of things for years in the early days (indeed, some still do). Bob |
#59 | |
There is substantial difference between MOSFET technologies. For instance, take IRFP240 (keep in mind this is in a smaller case compared to the bipolars mentioned, and specified 150W at 25C), we have at 100V / 10ms: Original IR: 3A Fairchild IRFP240B (Specced 180W @25C): 4.7A Interestingly: IR IRFP140: 3.1A IR IRFP140N: 2A (it is specced 140W though). It should also be noted that IR does not publich DC SOA for their parts at all (but Fairchild does). I'm not even going to begin comparing prices for 2SC3264 (which is no doubt an excellent BJT) and the lowly IRFP parts. You could look at this in another way: make a single pair output stage. Take nearly any sensible device and you are limited to about +-40V rails calculating for a nominal 8 and actual 4 ohm load. Then, compare taking care of the price bracket, and you will find that it is very similar - in fact, although HEXFETs sometimes get a fraction of an amp ahead, in either case, you are well advised to provide some sort of proper SOA limiting. Basically, comparing IRFP240 and 2SC5200 and similar devices is a fair comparison. That being said, I have never had a current limited MOSFET not survive a fuse (sensibly chosen, of course!), but I do take care of one thing: avoiding gate punchthrough either by oscillation of overvoltage. The failure rate of HEXFETs in designs where this is not assured, is in my experience 100%. |
#60 |
What is important is what works. Sometimes, a Japanese part will be expensive, but since I have my power amps made in Taiwan, the parts are what the Taiwanese select as what is easily available. Fairchild (IR) devices are superior, and what I normally use for audio applications.
I am happy that the Toshiba 2SJ201 parts are really better than I first thought. That leaves it easier for me to use them in future. I would be careful however, I have been 'burned' before. |
