#141 | |
Umm.....0k. To me, it's easier to determine which of two power amplifiers, one with a 20kHz THD of 0.01% and the other with a 20kHz THD of 0.001%, is more "perfect" in terms of THD performance than the other by testing them on a distortion analyser than listening to them. |
#142 | |
What happen to measured differences on low output power, if they were measured on high power? How capacitive character of load change them? Why BJT, MOSFET, tube outputs with the same THD level on relatively high power sound so different on low power? The question was, if such non-significant according to measurements differences are audible....
If I disappear suddenly, that means I finally created a time machine and pushed wrong button that brought me to Stalin's Russia. In any experiment any result is the result. Even if it is negative. |
#143 | |
I have read at several different sources that 0.1% THD is at the limit to human hearing. This means both those amplifiers are perfect by THD criteria only at a specific level, at a specific test frequency and with a specific test load and no one will truly be able to hear anything different under those specific circumstances When we talk levels of 0.50% THD or more, in relation to one other 0.01% THD amplifier we can most probably say one is more HiFi, high fidelity, ( in true meaning of word, which is like: more accurate in signal reproduction ) than the other -------------- Note!High Fidelity does not necessary mean sounding better, a more pleasing sound. It means you get output in accordance what you input. For better or for worse. -------------- Say an artist produce a recorded song, which is very dissonantly mixed and produced and both lyrics and musical sound is intended to express a worrying feeling - discomfort. Now some NOT HiFi amplifier may add some even harmonies, 2nd 4th harmonics into this song. This would destroy the intended artwork in its original form. An HiFi, High Fidelity, amplifier is fidel, =true, to the original at such level it is impossible to tell difference from original recording by ears. ------------- A very good sounding amplifier may well be Not HiFi - high fidelity, but InFi - infidelity, which also is called LowFi - low fidelity. But this infidelity is such, that in most listened kinds of music, it is more pleasing. Easier to your ears and mind. ------------- Finally, we can not judge either HiFi or LowFi amplifiers as being all bad. As long as anyone likes one or the other and wants to use them, it is good to those who enjoys them. Taste is difference, thinking is different and isn't this very good and interesting thing! Indifference would be extremely boring One might just as well go put an end to such an excuse for a life. thinks lineup you may think totally different
lineup |
#144 | |
I’d like to elaborate a bit further in the levels of power dissipation under quiescent conditions. That 1kW into 4 ohm hypothetical design with a 89V peak voltage swing may have +/-110V rail voltages. With 10 paralleled MOSFET pairs biased to 200mA each we have a total of 440W of power dissipation when the amplifier is just idling – that’s a hell of a lot of quiescent power dissipation for an amplifier only rated at 1000W RMS into the load. Using BJT devices of similar current and voltage ratings instead, that bias current could easily be cut down to one-fifth this level without sacrificing crossover distortion performance, giving an idle dissipation of 88W. That is a dramatic increase in efficiency. Another thing that should be said, is that just because an amplifier may be rated to deliver 1/8 of maximum rated power on a continuous basis (endless hours) without over heating, it does not mean that such an amplifier does not have reserves to operate at much higher ‘continuous’ levels for briefer periods of time – say 10 or thirty minutes. Now the hypothetical 1kW amplifier, with a BJT output stage and 88W of quiescent power dissipation would have much greater reserves to deliver high average power levels to the load before over heating than the equivalent MOSFET design with 440W of quiescent power dissipation - assuming both amplifiers have the same degree of heatsinking. The MOSFET design will idle much hotter and will therefore thermally limit much sooner when called upon to deliver high output power levels. The recovery time of the MOSFET amplifier after thermally limiting will also be much greater than the BJT design, as at 5 times the quiescent power dissipation, it will take much longer to cool down. The only way to alleviate this disadvantage of the MOSFET design is to heat sink it much more heavily than the equivalent BJT design – and that is a significant economical disadvantage. |
#145 |
The entire symmetrical-follower design is one big disadvantage in order to save electricity.
#146 | |
I think we are in pretty good agreement here, John. I have liked 20 kHz THD in the past because it is a tougher test, and it correlates well with HF non linearity that will also result in in-band IM. But you are absolutely right about the difficulty of seeing the higher-order harmonics of THD-20 with ordinarily-available spectral analysis tools. You are also right in suggesting that not all THD-20 is the same; the same number composed of benign 2nd and 3rd is much less objectionable than the same number containing equal amounts of harmonics out to the 7th or 10th. For this reason, these days I tend to focus more on CCIF 19 kHz + 20 kHz with full spectral analysis, since it still has reasonably good slew rate and HF stress, and readily shows the high-order IM products. Bob |
#147 | |
Well, I guess neither Bob Cordell or John Curl, two very well known audio designers, can answer my question. Or they just wont bother. Not even a comment .... Maybe because my, lineup status, in the inner circle of audio society is close to ZERO = 0.000000001. Humbly while under a deep bow to these cruel facts And with 1000 Regards lineup
lineup |
#148 | |
Glenn, You've made a HUGE mistake here. Your assumption that 10 pairs of paralleled MOSFETs would have to have a bias of 200 mA each for reasonable crossover distortion into 4 ohms is completely wrong. What matters in the creation of static crossover distortion is the variation in total transconductance of the output stage in relation to the impedance of the load. In very rough terms, the re if a bipolar transistor is on the order of 26 ohms/Ic in mA, and that of a MOSFET is on the order of 250 ohms/Id in mA. That is why we normally say that a MOSFET needs about ten times the bias current, all else remaining equal. Transconductance of both types of devices is roughtly proportional to current in this current range. A single MOSFET biased at 200 mA will have rs on the order of 1.2 ohm, the complementary pair on the order of 0.6 ohm. Let's say this ratio of 0.6 ohm against 4 ohms was OK for a 50W amplifier using a single pair of MOSFETs. The interesting thing is that this TOTAL amount of idle bias is STILL just as OK for the 1000 W amplifier using 10 pairs of MOSFETs paralleled each idling at 20 mA. Your logic in assuming that each of the ten pairs of MOSFETs would have to be biased at 200 mA was totally wrong. I'm not saying I'd bias them that low in practice in a 1000W amplifier, but I hope you get the point. I would probably bias them at some level such that the idle bias dissipation was still below the 1/8 power dissipation. That is why I asked you about whether your amplifier was rated to work continuously at 1/8 power. If it has to be adequately heat-sinked to withstand 1/8 power continuously, then it can ceratinly withstand a few hundred mA of idle bias. Cheers, Bob |
#149 | |
Sorry, I still disagree! I've worked on commercial high power MOSFET amps and have several articles of published designs which all run the individual bias currents of multiple parallel connected MOSFET pairs at anywhere from 100-200mA each. Perhaps my experience is limited, but I've never seen a high power MOSFET amp biased anywhere near as low as what you are suggesting. I've always seen the need for 100-200mA of bias current for each audio MOSFET not strictly for the reduction of x-over distortion but to bias each device nearest possible to the zero temperature coefficent point of vgs Vs Id so as to keep the bias current stable with the wild temperature variations that can occur in an abused high power amplifier. |
#150 |
I tend to agree Glen. It would be almost impossible for me to insert Mosfets where I now have power transistors and get the same power in a practical way.
Also, I would think that I would want to bias the power Mosfets at 80ma ea or more, just to keep them from increasing the higher order distortion component due to the rate of change of the Gm at very low currents. What is the advantage of power mosfets in high powered amps anyway? Lineup, I don't know exactly why you should get very high 9 harmonic distortion in a class A design. It would seem to be impossible. Maybe it is a computer program glitch. |
