#111 |
First, tell us more about your amplifier. What is its rated power into what load? Is it Class AB, G, or H, or something else? What is its rated THD-1 and THD-20 at full power? Is it specified to deliver 1/3 or 1/8 power continuously into its rated load without overheating? I am familiar with high-power amplifier design, having been involved in the design of the Crest 8001 (bipolar, Class-H).
I’ve designed and built various bipolar A, AB designs from 500-5000W with THD levels well below perceptible limits. These are not mass produced units, but mostly one-off designs either for my own use or for specific applications. Your point about the bias current for MOSFETs vs bipolar is well-taken, one of the reasons I designed my MOSFET amplifier with error correction back in 1982. The EC almost eliminates the problem of MOSFET transconductance droop in the crossover region. You can definitely get away with 20-50 mA of bias on a BJT if you're willing to accept only fair sonics. At 150 mA bias, my MOSFET amplifier did 0.02% THD-20 into 8 ohms without EC. I’m sorry, but I don’t agree with your assertion that a BJT amplifier biased to 20-50mA per device will only deliver “fair sonics”. That’s just plain absurd. The THD figure you quote isn’t particularly difficult to achieve in non-EC amplifiers with bipolar output stages and ultra low THD figures at 20kHz are superfluous anyway. If you can hear the second or third harmonic of 20kHz then you’re doing better than me. The Public Address, Pro Audio and Audiophile markets are very different. In the latter, it is quite common for high-end amplifiers to operate in Class AAB, with output devices somewhat over-biased, for best sonics. There is less concern about idle dissipation in the audiophile arena. At the same time, there is very much more concern for high-frequency linearity. OK, but I don’t design for the esoteric audiophile market. I’m interested in producing efficient cost effective designs. Heat dissipation must be kept to a minimum and in that regard BJT’s with their much lower bias current requirements and ability to run at high temperatures without throttling back rule supreme. Please define better what you mean by compression distortion. I don't believe my MOSFET amplifier suffers from it, be it from reduced transconductance or not. At high currents, gm of MOSFETs is plenty. I didn’t say that the gm of Mosfets wasn’t plenty for linear amplification, I was making a comparison to BJT’s which have a much higher transconductance and therefore suffer from a particular distortion mechanism to a lesser degree than Mosfets devices. In source follower configurations the instantaneous output voltage is equal to the voltage at the gate minus the gate to source voltage, which for some devices can become significantly non linear at higher currents. The MJL21193 transistors you mention are very slow devices by today's standards, with an ft of only 4 MHz. That is adequate for PA applications, but certainly not for high-end audio. I didn’t cite the MJL21193 as the best audio transistor out there, but as a unit with comparable robustness, as that is what you had asked for. They are also not less expensive than IRFP240s. I don't know where you got your numbers, but at DigiKey, the MJL21193 is $3.78 in QTY 100, while the IRFP240 is only $1.71. Things are obviously better where you are. I was comparing it to the TO3 IRF240, which from an Australian supplier costs approximately 50% more than both the MJ21193 and MJL21193. I didn’t get a price on the IRFP240. It's unfortunate that the MJL21193 is not rated for SOA at 10 ms, which is what is the more important number for audio. The data sheets only provide limited information. That does not mean the MJL21193 will not withstand much high dissipation levels for brief 10mS bursts. I haven’t subjected one to destructive testing, but going by it’s robust 1 second rating I doubt that it would be much less able, if at all, than the IRF240 device. Cheers, Glen |
#112 | |
regards, Gerhard |
#113 |
Bob, Just to further elaborate on the results that can be achieved with bipolar output stages, I provide a link to a rather basic, albeit refined Douglas Self design that does not use error correction and is of comparable power specification to your MOSFET design: http://www.dself.dsl.pipex.com/ampins/dipa/dipa.htm It produces less than 0.02% THD at 40kHz delivering 40W into 8 ohms. I have never published my designs, but I have achieved similar results using paralleled MJL21193/MJL21194 complementary pairs at 15 times this power figure - devices which you assert are not suitable for high-end audio. Cheers, Glen |
#114 | |
If I disappear suddenly, that means I finally created a time machine and pushed wrong button that brought me to Stalin's Russia. In any experiment any result is the result. Even if it is negative. |
#115 |
Wavebourn:
I can hear intermodulation between 20 KHz and 20100Hz well. OK, but how well can you hear the intermodulation products between the 2nd harmonic of 20kHz and 20100Hz?
#116 | |
I don't know. ![]() Also, I can distinguish natural sibiliant consonants from distorted.
#117 |
Wavebourn:
Also, I can distinguish natural sibiliant consonants from distorted. Man, I don't even know what sibiliant consonants are, but that sounds impressive. I can identify between the 400Hz and 1kHz test tones of my RF amp test rig without looking at the frequency switch.....usually. Am I similarly gifted?
#118 | |
Another thing which is worth noting is that in this design D.Self used the now rather old hat Bipolar MJ802/MJ4502 complementary pair - transistors which only have an fT of 2MHz - half that of the MJL21193/MJL21194 complementary pairs 4MHz fT. The MJ802/MJ4502 transistors also have quite inferior hfe Vs collector current linearity. In my designs using the MJL21193/MJL21194 pairs I run larger emitter resistors and a bias current of 40-50mA. Cheers, Glen |
#119 |
Account Disabled
ok
#120 |
diyAudio Moderator Emeritus
Hi, Bob Cordell,
What is your opinion about quasi complementary output stage (that uses all NPN devices)? It can be seen that the positive part is common collector, while the negative part is common emitor usage mode of output transistors, so it is not balanced between positive and negative half. What is the merit and drawback of this quasi complementary output stage? |
