Old 11th May 2007, 06:05 PM   #1
Zeljko is offline Zeljko  Croatia
Question Question about FET 2SK117 in old stereo receiver
I have an old stereo receiver which has two FETs in preamplifier stage, they are 2SK117 and probably they doesn't work. I bought new 2sk117, but what I wish to know; original FET was 2sk117 GR and I have new 2SK117Y. The different between those two FETs is in IDSS,
Y has 1.2~3.0 mA, GR has 2.6~6.5 mA, BL has 6~14 mA.
So my question is, can I use this 2SK117 Y instead 2SK117 GR (Service manual recommended to use 2SK117 GR or BL). What will be if I use that 2SK117Y ?
Regards!
Old 11th May 2007, 09:10 PM   #2
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Default Re: Question about FET 2SK117 in old stereo receiver
Regards!
1. mebbe it will work ok
2. mebbe it will sound sound distorted
3. mebbe it will go puf
just try them
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery
Old 11th May 2007, 09:40 PM   #3
EUVL is offline EUVL  Europe
I would also recommend you to use GR or BL. Using Y will probably place the FETs in positive-bias (if e.g. driven by a CCS) -- bad idea.
But it will make life much easier if you have the schematics.
Patrick
Old 12th May 2007, 10:20 AM   #4
Patrick
OK, here it is...
Regards!
Old 12th May 2007, 12:22 PM   #5
EchoWars's Avatar
Are you sure the old ones are bad? They aren't known for failure...
One part on your schematic IS known for high-failure...D1 and D2, the VD1212 diodes. They can be replaced with a simple series pair of 1N4148 diodes. If you're having problems with that part of the preamp, get rid of the VD1212 diodes first. Every time I find them, I pull them out.
...looks like a Sansui something-or-other...
Old 12th May 2007, 05:57 PM   #6
I am thinking that someone has connected DVD Player or CD player on that Phono input…
I checked those two diodes by digital multimeter, and they are good.
Yes, it is Sansui receiver
What's new on AK ?
Regards!
Old 12th May 2007, 06:15 PM   #7
Netlist is offline Netlist  Belgium
Netlist's Avatar
Type number?
/Hugo
Old 12th May 2007, 09:14 PM   #8
Originally posted by Netlist
Type number?
G8000
Regards!
Old 13th May 2007, 05:56 AM   #9
EchoWars's Avatar
Well, they nearly always check out fine with the tiny current that a meter puts through them.
I'm not sure that feeding the phono input with a CD player would kill it. I don't think it would have sounded very good, but it really should not blow up the phono stage.
Is the phono dead? Or just sound bad?
Old 13th May 2007, 08:34 AM   #10
On what better way I can check this diode?
I got this receiver in very bad condition, and both channels on this phono stage are dead. I bought in local store some 2SK117 but not BR or GR, just only Y (as I written before different is only in IDSS). So, what will be if I replace that original with this Y FETs? Can it work for a long time, if it will work?
Regards!
70s Era Receiver Not Locking On Stereo DreadPirate Solid State 1 29th September 2007 06:54 PM
Technics SA5550 Stereo Receiver lawbadman Solid State 0 9th September 2007 07:29 AM
Using 5 channel receiver for stereo sub and speakers renfrow Subwoofers 7 21st September 2006 03:17 PM
Stereo Amp/receiver For Guitar Use DIRTEEMONKEE Solid State 0 26th October 2004 04:40 PM
Stereo Receiver Trouble Shooting... manxam Solid State 6 4th January 2004 01:45 AM
Page generated in 0.12638 seconds (78.62% PHP - 21.38% MySQL) with 11 queries
