#21 |
Zeljko,
The schematics you posted showed the 2SK117s being using as a diff pair at the inputwith no source degeneration. They are driven by a current source with about 8mA constant current ((12V-0.6V)/150R). This determines what you need for the 2SK117s, namely, they should be matched devices with Idss of about 8mA (I would not go much lower than 6mA even if you assume you never get full swing on the diff pair due to negative feedback). That means GR or (better still) BL. They will see half of that, i.e. about 4mA, with no input signal. 2SK117Y has a max Idss of 3mA, which means that you will forward bias them even with no signal. I would advise you against that but others seem to have another opinion, though I have yet to hear their arguments. If you have difficulties getting 2SK117BL (though they seems to be quite available), you can replace them with 2SK170BLs without too much difficulty. The capacitances are higher by a factor of 2, but transconductances is also 50% higher. Failing all that, send me a private email. I can probably help you, but only for once, with 2 matched pairs 2SK117BLs. Patrick |
#22 | ||||
Regards! |
#23 | |
Patrick.............. ECA VRT sez for that VD1212 diode : "1,24..1,34V(1,5mA) " so CCS seems that have smaller current...........
my Papa is smarter than your Nelson ! tnx to |
#24 | |
hehe and not 76mA ,fer sure.........
#25 |
> "1,24..1,34V(1,5mA) " My mistake (too lazy in the morning to check datasheet). I take back what I said and apologise to all, especially to Zeljko. If 1.34V, then CCS has current = (1.34-0.6)/150 = 5mA Each FET (2SK117) will have bias at 2.5mA, and 5mA max. In that case I would still use GR with Idss >= 5mA. (One can argue that one can use Y with Idss 3mA and let the JFET goes into slight positive bias. For me it is bad practice, plus that the chances of getting max. Idss as in spec are, from experience, not great. So the recommendation for GR or BL stands.) > How you can find matched pairs of 2SK117? Buy 100 pcs and match myself. 2SK117 is the JFET of choice by Japanese DIYers (promoted by Kaneda) because they have the lowest capacitance / transconductance. Patrick |
#26 |
OK, I learned so much about those FETs in this therad, thank you guys, especially to Zen Mod and Patrick!
But now, I have one big problem, when I have found 2SK117Y in my local store, I was so happy that I bought 50 pieces of them Regards! |
#27 | |
can you change them for anything else (BL marked) in same shop?
#28 | |
![]() Zeljko |
#29 | |
just put these Ys in place and try it
| 70s Era Receiver Not Locking On Stereo | DreadPirate | Solid State | 1 | 29th September 2007 05:54 PM |
| Technics SA5550 Stereo Receiver | lawbadman | Solid State | 0 | 9th September 2007 06:29 AM |
| Using 5 channel receiver for stereo sub and speakers | renfrow | Subwoofers | 7 | 21st September 2006 02:17 PM |
| Stereo Amp/receiver For Guitar Use | DIRTEEMONKEE | Solid State | 0 | 26th October 2004 03:40 PM |
| Stereo Receiver Trouble Shooting... | manxam | Solid State | 6 | 4th January 2004 12:45 AM |
| Page generated in 0.12305 seconds (82.91% PHP - 17.09% MySQL) with 11 queries |
