I'm trying to design an 8 channel audio setup for a sound art installation, but I'm having a bit of trouble juggling all the variables. I have some unusual requirements. The basic setup will be eight speakers arranged in a circle with a 10ft radius. I'll be building the speakers to spec as well.
I'm considering just using a bunch of LM386s, but that's mostly because I'm completely ignorant. Here's my requirements:[list=1][*]12V DC power supply[*]Low power consumption - it's running off a car battery (possibly with solar trickle charge)[*]Decent enough sound quality to reproduce synthesized human speech - it sounds crappy already, so it doesn't need to be audiophile[*]60dB at 8ft - I know this depends on the speakers but I'll probably be using a pair of cheap 0.25W 8 ohm speakers in each cabinet (any recommendations appreciated here too).[*]Robust - it needs to be able to run unattended for days out in the desert heat[/list=1] You can read up on the project details if you're interested in what this thing will be doing. Thanks! |
#2 |
Should I just buy a couple of these Amp32 kits and call it a day?
http://www.41hz.com/main.aspx?pageID=105 I think they're way overkill for what I need, but they appear to be very high efficiency and look well-suited to running off a car battery. |
#3 |
They would would certainly work well in your application, though you might need quite a few solar cells to power the rig. As for speakers, in your position, I'd be looking at cheap 4 Ohm car jobbies.
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
| Creating 5.1 Multi Channel sound from 2 channel | jenkrich | Everything Else | 5 | 1st September 2009 07:29 AM |
| crackling sound from one channel | ali_azamkhan | Tubes / Valves | 4 | 23rd November 2007 09:43 PM |
| Sony CDP-X3000ES no sound on right channel | Bernhard | Digital Source | 7 | 29th July 2007 09:03 PM |
| 6-channel USB Sound Card | marcin-k3 | Digital Source | 1 | 3rd August 2005 09:52 PM |
| Sound deadening mat installation Q's | curtis73 | Car Audio | 2 | 25th October 2004 05:26 AM |
| Page generated in 0.07496 seconds (68.25% PHP - 31.75% MySQL) with 10 queries |
