diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Solid State (http://www.diyaudio.com/forums/solid-state/)
-   -   Anyone know a NEC K821 Replacement? (http://www.diyaudio.com/forums/solid-state/101683-anyone-know-nec-k821-replacement.html)
KyferEz 10th May 2007 05:46 PM
Working on a Mobile Authority 120ZX. It has 4 of the NEC K812 for the power supply that need replacement.
I checked NEC and they say it's obsolete. Suggestions?
sixtek 10th May 2007 06:14 PM
Try 2SK1296 or 2SK1291 - if they are available there.
KyferEz 10th May 2007 06:33 PM
Thanks. Mcminone has the 2SK1296. Off on another ordering spree :D
sixtek 10th May 2007 06:45 PM
Checked in my other substitute pocketbook and that says 2SK1296 too ;)
So I'm sure that will works!
KyferEz 5th June 2007 05:58 PM
Back to working on this amp; I just got in the parts.
It's working now, but the 2 right channels are not as loud as the 2 left channels. Why would this be?
sixtek 5th June 2007 07:57 PM
Is the bias of OP devices readjusted yet?
KyferEz 5th June 2007 11:38 PM
I'm sorta new to this, so some more explanation is needed... Are you talking about the pots in each channel of the outputs?
If so, how do I properly adjust them? I've attached an image so you can see the output stage of this amp.
P.S. In case it's needed for this, I do have a good scope...
http://s210.photobucket.com/albums/b...t=IMGP1323.jpg
KyferEz 7th June 2007 07:32 PM
Anyone?
Copyright ©1999-2013 diyAudio
