Need to build JC 2 preamp - Page 39 - diyAudio
Old 15th March 2013, 05:32 PM   #381
pidigi is offline pidigi  Italy
Originally Posted by gk7 View Post
5.6mA seems rather low to me, this is 1/3 of the "V" parts I use. I would not
cheap out on these parts and order them form Spencer ("BL" grade), as long as
he still has 2SJ74 available, and ask for the highest Idss matched quads he
can offer (should be around 10mA or so).
thank you Georg, I will follow your suggestion
I can confirm that the "-4dB" setting (this is 17dB gain from the line stage) is
stable; how much feedback you can apply to lower the gain without stability problems
I donīt know. (I would estimate that the gain has to be > 3 at least).
seems I made a mistake in my question, I meant low gain + low feedback or high gain + high feedback. But you got he point.
Ciao
Paolo
Old 15th March 2013, 06:03 PM   #382
john curl's Avatar
A 2SK246-2SJ103 combination would work OK for the JC-2 line stage.
"Condemnation without Examination is Prejudice"
Old 15th March 2013, 09:22 PM   #383
thank you John for chiming in!!
Old 16th March 2013, 02:01 PM   #384
gk7 is offline gk7
Thanks John, thatīs good to know.
Old 18th March 2013, 02:33 PM   #385
I am trying to match the jfets (yes, I know that I can buy them already matched but I have some around that I would like to use), but I see that there can be a significant difference in Vgs between similar (<1%) Idss devices. In this particular application is better to closely match them for Idss or Vgs? ....or both?
Thanks,
Paolo
Old 18th March 2013, 04:56 PM   #386
When Vgs = 0, then you have Idss.
In other words when you select two same Idss devices and bias them to that value of current then the Vgs MUST be the same for the two devices.
If you were to bias the two devices to a lower value current, Id, then you will have a Vgs for each device. Now it is quite likely that the Vgs will not be the same for the two selected devices at this lower Id.
The Vgs follows a slope when plotted against Id.
Matching the SLOPE of the Vgs between devices is what matching jFETs is about.
Selecting a pair, or a quad, of same Idss devices is not matching, even though some Members sell devices with the "matched" description attached.
If you intend to bias your jFETs at a different current value from the Idss, then you should be matching the slope of Vgs vs Id, if the circuit requires similar parameters for designed performance.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 19th March 2013, 01:54 PM   #387
Thanks Andrew.
What if I match them for Idss and Vgs? I mean, can this matching be considered like having matched them for Vgs vs Id slope?
Old 19th March 2013, 01:59 PM   #388
Georg, I have seen in your last version that you used a trimmer between the bases of the output transistor in order to set the offset. Is this the best solution? I am asking because I have seen somewhere that a trimmer in place of R2 has been used. Basically I agree with your solution, if a matched quad of jfets is used.
Old 19th March 2013, 05:19 PM   #389
I don't think you understand what I have been posting.
regards Andrew T.
Old 19th March 2013, 07:00 PM   #390
Andrew, maybe I don'understand or I didn't make myself clear. What I mean is that the relationship between Vgs and Id should be quite clearly defined, so if I have 2 devices with same Idss and Vt then the slope should be the same. Is it correct?
What preamp should I build? OzMikeH Tubes / Valves 154 21st January 2009 12:07 PM
BDT Preamp build jkeny Tubes / Valves 13 5th November 2008 01:37 AM
Build Preamp Jpoole908 Solid State 1 8th June 2008 01:47 AM
Copyright Đ1999-2017 diyAudio
