Need to build JC 2 preamp - Page 38 - diyAudio
Old 12th March 2013, 03:21 PM   #371
gk7 is offline gk7
Originally Posted by transistormarkj View Post
They changed the process for these fets, they are not low noise like they
used to be 40 years ago. To quote John Curl: "I found that Siliconix J110's , that I originally spec'd for the JC-2, over 35 years ago,
got VERY noisy in the late 70's, and remain so today, because they switched to ion implantation."
Old 12th March 2013, 04:17 PM   #372
Originally Posted by pidigi View Post
Hi Andrew,
are you meaning that only the V (or at least BL) version of the 2SK170/2SJ74 is suitable for this application?
Do you maybe know about other possible replacements?
Thank you,
Paolo
the 246/103 is not a good replacement for the 170/74
I think the specified grade for the 170/74 is BL. GR is too low Idss and that limits the gain and transconductance.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 12th March 2013, 04:26 PM   #373
pidigi is offline pidigi  Italy
Originally Posted by gk7 View Post
...... Attached is the block diagram of the JC-2 / ML-1
thank you Georg!!! I was missing this schematic!
...and then another question arise: if I don't use the balance switch, should I use the resistor combination of the "zero" position?
10k potentiometer with 20k before it (in the "low" gain position). You could use a potentiometer in the 20k - 30k range (without the the high / low switch).
ok, I see the point now.
No they donīt perform better (I use 2SA1209 and 2SC2911 myself) but the 2SA1381/2SC3503 are more readily available (at Mouser for example).
perfect, I will stay with the 2SA1209 and 2SC2911 then!
Thanks!
Paolo
Old 12th March 2013, 04:48 PM   #374
Hi Andrew,
then the right question should be: which is the most similar device respect to the original one, 212/75? Considering a 170 with the same Idss of a 246, from datasheet the first has a gm of 22 and the second of 9. The J212 datasheet (at least the one that is available now) says a gm of 12.
Where am I wrong (and sure I am )?
Old 13th March 2013, 08:46 AM   #375
The highest Idss pair of 170/74 GR you can get.
regards Andrew T.
Old 13th March 2013, 10:55 AM   #376
gk7 is offline gk7
I just had a look at FET Audio | Hi-End Audio Projects (Spencer is a member here),
an they still have 2SJ74 / 2SK170 matched in BL grade.
Spencer even has matched quads (quote: "Maximum match is 4 pcs K170 and 4 pcs J74 with same idss match together in one group.")
Matched quads is what I used with good results for my build.
Old 13th March 2013, 03:44 PM   #377
gk7 is offline gk7
If you combine all resistors in the feedback loop (at the "zero" position) you
get 21.3 kOhms. With the 2kOhms to ground this is 21 dB gain.
If this suits your needs depends on the voltage gain of your power amplifier.
Personally I have never needed to use the "high" position on my ML-1 ("low"
attenuates by approx. -10dB this results in a total gain of 11dB).
Old 13th March 2013, 04:25 PM   #378
I don't need a lot of gain, I think that 10dB is plenty.
I am wondering now if it is better to use the "low" gain setting (attenuating the input) and a "zero position setting" (or "higher feedback setting") of the feedback or a zero attenuation and a "higher feedback setting"......
Am I worring too much?
Thank you Georg
Old 13th March 2013, 04:27 PM   #379
5.6mA is the highest Idss for a quad match I can reach. Is it too low or it is worth trying?
Thanks,
Paolo
Old 15th March 2013, 09:14 AM   #380
gk7 is offline gk7
5.6mA seems rather low to me, this is 1/3 of the "V" parts I use. I would not
cheap out on these parts and order them form Spencer ("BL" grade), as long as
he still has 2SJ74 available, and ask for the highest Idss matched quads he
can offer (should be around 10mA or so).
I can confirm that the "-4dB" setting (this is 17dB gain from the line stage) is
stable; how much feedback you can apply to lower the gain without stability problems
I donīt know. (I would estimate that the gain has to be > 3 at least).
What preamp should I build? OzMikeH Tubes / Valves 154 21st January 2009 11:07 AM
BDT Preamp build jkeny Tubes / Valves 13 5th November 2008 12:37 AM
Build Preamp Jpoole908 Solid State 1 8th June 2008 12:47 AM
Copyright Đ1999-2017 diyAudio
