Need to build JC 2 preamp
Old 20th April 2013, 01:36 AM   #421
elektroj is offline elektroj  Europe
Originally Posted by gk7 View Post
R8, R9, R10 are not present in Johns schematic, but my original modules obviously have a second pot for offset adjustment so I "borrowed" this from the ML-2 power amplifier which uses the same topology as input stage.
Thanks for the info, gk7. So, it was a bit of guesswork.. Did John "blessed" it?
Please post it, Iīm curious to see it.
It's a ML-5 record amplifier. PM me with you email - I'll send you some more.
Old 23rd April 2013, 04:51 PM   #422
ivodonchev is offline ivodonchev  Bulgaria
Hi guys,
because I do not need a phono stage, is it possible to build the preamp in the way shown in the picture?
Are there any possible problems with the stability?
Any ideas are welcome!
Old 23rd April 2013, 05:09 PM   #423
john curl is offline john curl  United States
john curl's Avatar
You make it too complex. Don't use the first gain block. Come in directly to the gain pot. That is how we do it.
"Condemnation without Examination is Prejudice"
Old 23rd April 2013, 05:27 PM   #424
gk7 is offline gk7
This one I knew, but whatīs inside the ULD modules ?
Old 23rd April 2013, 06:22 PM   #425
Thank you Mr. John Curl,
You are right - the simpler schematic is better. But in my case I have tube out CD Player which is anode out and the output impedance is around 1-1.2k which is too high to drive 10k gain pot. That is the reason to put the first gain block. Is there any other technique to avoid the use of the first module? In my case, what would you do?
Thank you in advance
Ivo
Old 23rd April 2013, 06:27 PM   #426
john curl's Avatar
It would be best to just use an open loop dual fet follower.
Old 24th April 2013, 12:30 AM   #427
gk7, if you look at the ML-1 manual that YOU posted, you will see that line amps in the schematics are also marked ULD-4 :-)
Old 24th April 2013, 06:13 AM   #428
gk7 is offline gk7
Yes, I know. And what does this tell us about the content of the ULD-4 ? I donīt get your point.
Old 24th April 2013, 06:23 AM   #429
gk7 is offline gk7
Here is a nice one ;-)
http://www.diyaudio.com/forums/analo...ml#post3431096
Could be made with a LSK389:
http://www.linearsystems.com/assets/...ets/LSK389.pdf
Old 24th April 2013, 09:31 AM   #430
Ivo
located at the tube output.
regards Andrew T.
Need to build JC 2 preampHide this!Advertise here!
What preamp should I build? OzMikeH Tubes / Valves 154 21st January 2009 11:07 AM
BDT Preamp build jkeny Tubes / Valves 13 5th November 2008 12:37 AM
Build Preamp Jpoole908 Solid State 1 8th June 2008 12:47 AM
Copyright ©1999-2017 diyAudio
