Audibility of output coils
Closed Thread
Old 8th May 2007, 01:18 AM   #101
dimitri is offline dimitri  United States
dimitri's Avatar
Send a message via ICQ to dimitri
However I am now stuck with a .3 ohm resistor in each output of my power amps.
I presume, noninductive ones?
Old 8th May 2007, 01:50 AM   #102
john curl is offline john curl  United States
john curl's Avatar
Yes, they parallel my Bybee devices.
"Condemnation without Examination is Prejudice"
Old 8th May 2007, 01:55 AM   #103
dimitri's Avatar
where you got .6Ohm bybee? Mine are 25mOhm
or you mean .3Ohm in parallel with bybee?
Old 8th May 2007, 01:56 AM   #104
Hartono is offline Hartono  Indonesia
KEWL
Old 8th May 2007, 02:18 AM   #105
john curl's Avatar
I have OLD Bybee devices. They use .3 ohm.
Old 8th May 2007, 02:47 AM   #106
dimitri's Avatar
Again the same trick. You had already accumulated with Erno all valuable old Toshiba JFETs. The leftovers become 10 times more expensive than before. And now OLD bybees.
Old 8th May 2007, 02:51 AM   #107
Terry Demol is offline Terry Demol  Australia
Terry Demol's Avatar
Originally posted by john curl
.5uH only for Halcro. Why don't you folks stop talking and start calculating?
John,
Are you referring to the large coil that looks like it is made of
copper tubing and has a large brass fitting at one end?
I believe it is also to block external RF from entering the amp.
Interesting amp for sure, however it looks like the much cheaper
balanced Bruno Putzeys amp is pretty close in measured performance.
cheers
Terry
Old 8th May 2007, 02:53 AM   #108
john curl's Avatar
Calculate the inductance from the MEASURED 20KHz impedance as measured by 'Stereophile'. What is wrong with everybody? Are there no engineers here?
Old 8th May 2007, 03:05 AM   #109
andy_c is offline andy_c  United States
Banned
John, I get 0.78uH. I got this from:
L = sqrt(0.14^2 - 0.1^2) / (2 * pi * 20e3)
R = 0.1 and
sqrt(R^2 + X^2) = 0.14 @ 20 kHz and
X = omega * L (neglect the parallel R)
This is for the DM88
Old 8th May 2007, 03:12 AM   #110
GK is offline GK  Australia
So what John? It's still a large air wound inductor, isn't it?
You have made the claim than any output inductor compromises an amplifiers sonic ability. Are 0.5uH inductors now all of a sudden OK in your opinion?
Glen
Closed Thread
Audibility of output coilsHide this!Advertise here!
