Old 7th May 2007, 07:22 AM   #1
sparkle's Avatar
Default ASR Shafer Emitter 1 and 2
Does anyone have anything more about those amps other than it is written on their site....
http://www.asraudio.de/
thanks
regards
daniel
Old 7th May 2007, 08:37 AM   #2
sparkle's Avatar
in their papers ASR is telling us that they use volume control that is not in the signal path....
my opinion is that it is probably in the feedback (becuase at the input ASR is using AD843 opamps)....
any opinions how to control gain in order not to have that control directly on the signal path..?....
Old 7th May 2007, 10:51 AM   #3
A total volume control using the feedback loop would make an amp that sounds a lot different at low, mid, and high volume. It would very difficult to impliment without sonic penalties worse than the sound of a pot in the signal path.
Are you sure they are not decribing a shunt volume control?
I copied the ASR Emitter II chassis scheme in an amp. Four chassis, one for circuitry, one battery supply for opamp input stages, and seperate ac suppplies for the output stages.
I liked the results. Batteries with lots of decoupling are great for opamp input stages. Did sound better than a regulated supply powered from the rails.
George
Cheapest is bestest
Old 7th May 2007, 11:27 AM   #4
sparkle's Avatar
i don't know about the volume control ..... they say it is not at the signal path - whatever that means...
i did not understand - have you made Emitter or you just used the principle of those 4 chasis and use it on some normal amplifier ?
Old 7th May 2007, 12:32 PM   #5
destroyer X's Avatar
Default Well...they are so pretty that i could have it only to decorate my home
The clear blue and this one are extremelly pretty.
Do not need to sound good...those one are to be watched only.
If sound good too...well..in this case we found something to dream.
regards,
Carlos
Try to build an amplifier folks ... it is pure adrenaline!
Old 7th May 2007, 12:46 PM   #6
sparkle's Avatar
it is a dream to me all right....
but to build similar quality amp........dream, dream on
Old 7th May 2007, 12:53 PM   #7
Default Dreams...this is what move us... we must be happy that we have them
So... tomorrow will be another day...and we will make our dreams come true...will make them a reality one day.
regards,
Carlos
Old 7th May 2007, 01:49 PM   #8
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
The Schäfer & Rumpf has relay switched shunt volume adjustment since the 1999 update.
German school amp, along with AVM and SAC, which also started manufacturing opamp imput power amps in the 1980s.
Just like Sphinx overhere and Greggy Ball in Ozland with his Eidetics.
I've seen the Emiiter-I go through so many stages that i've lost count
Interesting project for DIYs, with regard to the powersupply philosophy and chassis building.
Biggest effort will be designing the board layout (if you own a pro package for that size)
Looks like Sponge Bob has killed another thread.
Old 7th May 2007, 02:15 PM   #9
sparkle's Avatar
jacco ... the biggest problem is the schematic not the board......
Old 7th May 2007, 03:08 PM   #10
The output stage of the Emitter I/II is not spectacular.
German school generally means driving the output stage from the rails of the opamp, Scylla is another example from overhere that manufactured power amps like that.
Lots of example schematics to be found here and on the web. ASR even tells you which opamp and mosfet brand/type to use, such as
here
here
The big job is combining all the different operations, and the hardware part. That's the challenge for a diy person.
Ever heard a Schäfer & Rumpf Emitter amp, btw ?
help... diode on emitter tomat Solid State 4 17th November 2008 05:01 AM
Why are Emitter-resistors needed? Fritzell Solid State 11 5th February 2007 06:04 PM
Emitter Resistors hawkfeather Solid State 15 29th January 2006 05:28 AM
Emitter Resistors EchoWars Solid State 16 16th July 2005 10:47 PM
where is the emitter resistor? homer09 Solid State 9 21st January 2004 07:38 AM
Page generated in 0.11563 seconds (80.71% PHP - 19.29% MySQL) with 11 queries
