Old 18th May 2007, 06:33 PM   #141
TOINO is offline TOINO  Portugal
TOINO's Avatar
I have already tried that but in vain...
Old 19th May 2007, 03:12 PM   #142
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
Try again...
I use to feel like the small child in The Emperor's New Clothes tale
Old 20th May 2007, 01:52 AM   #143
TOINO's Avatar
You can close the door again
Yo no creo en brujas pero que las hay... las hay (Cervantes)
Old 4th June 2012, 06:03 PM   #144
DjLeco is offline DjLeco  Romania
Send a message via Yahoo to DjLeco
Originally Posted by Eva View Post
This waveform that you call junk is carefully shaped to exhibit exactly the same average value as the own audio signal, so it does not produce any distortion, it only adds carrier residuals to the output, 630Khz (or whatever) and its harmonics. This is the trick. You are telling us that you don't understand switching mode electronics at all, and as a result, you just hate it, you call it junk and you discard it (typical human behaviour).
There is nothing wrong with shaping audio signals through high frequency carriers and integrating the HF stuff back to get the audio stuff. Rail modulation is actually a nice thing because output devices are operating at constant Vce at audio frequencies and this makes them more linear.
Very good said here, Eva!
Also at 7,5 Vdc between Emmiter and Colector at AB class bipolar stage, SOA, is ENORMOUS, instead greater Vce, for bipolar transistors!
Practically under 10Vce is maximum current disponibility from transistor as shown, best SOA possible!
http://postimage.org/image/4c20scdfz/
Old 22nd October 2012, 10:14 PM   #145
Epoxy or just a thick lacqer coat to make the assembled PCB moisture-proof can make wornders. Sensitive parts are the big coils and capacitors as usual.
Here you can see an early prototype:
This included PFC or not? And it is of 4.8Kw?
Copyright ©1999-2013 diyAudio
