#11 |
Did it Himself
If radio is your main source that is probably your problem.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#12 |
Maybe you should try another speakers, have you ever heared danish sound? maybe scan speak? or bi-amp or tri-amp your sistem?
Cheers Pancho |
#13 |
I agree with you Pancho, when I changed my old speakers and try with danish speakers, my ears were overcome with joy!!!
Now I 'm going to try is triamp. or fouramp. my system
La vida es bella. |
#14 |
la vida es bella pero no barata
ustedes bien saben que por estas latitudes a todos nosotros todo nos sale el doble......hay que solucionar el problema con lo que uno posee....y de reventa no te pagan nada por mejor estado que este. radio is my problem ok...but in other sources th problem is similar
audio |
#15 |
Hi tadiam, you are right, life is beautifull but not cheap, I've been waiting about 30 years to multiamplifier my system.
Es cierto cuando queres vender no te dan nada. Si necesitas una mano....pedí nomás... Cheers Iván
La vida es bella. |
#16 |
ok ivan gracias
Los ls 70 mios los compre hace 10 ańos nuevos y pasaron la mayor parte de su vida dentro de la caja casi nunca los useya que tengo un segundo par de monitores infinity. Los ls estan nuevos y por lo que te dan ni siquiera compras un modelo nuevo de inferior calidad. si qures enviame tu correo Diego
audio |
| hello diyers | semperfidelis | Introductions | 3 | 14th September 2006 04:24 PM |
| MY new toy, funish kit for diyers....................... | siu sin man tho | Digital Source | 0 | 16th July 2004 10:41 AM |
| Page generated in 0.08369 seconds (71.56% PHP - 28.44% MySQL) with 10 queries |
