Hi Guys
I am building this J-Fet OP Amp for my new line pre-amp project but I have problem to adjust the 50R trim pot to read 0 at the output. Instead I got +20V at the jointing point of the two 10R resistors. Does any one can tell me is there anything wrong in this circuit caused the error? Thanks Chan |
#2 |
I don't have the skills to debug this problem, but a few more voltages appended to the schematic would help others find the fault. Would de-sensitising the 50r pot help? Adding 100r to both sides of the pot and then adding 33r from each source to the wiper. However, this is not a nice way to remove DC offset. It unbalances the LTP. Far better to trim the VAS bias current to adjust the voltage drop and current across the drain load R1. I wonder if R1 is too low? what voltage is here? I would use a matched pair of source resistors on the LTP (low to preserve gain) and then use these to check that LTP currents are really balanced (using the VAS trim)
regards Andrew T. |
#3 |
Hi Andrew
The voltage of R1 is 3V. Is this measurement correct? Thanks |
#4 |
one extra measurement is not nearly enough. But that 3V confirms 3mA into one half of the LTP. Because you cannot check the source resistor currents you cannot check the LTP balance and you cannot check the total tail current =stumped! I suspect that one half of the LTP is turned off or nearly so. Give us more voltages. We can use them to calculate what currents are flowing around your circuit. Could you remove the 50r pot and temporarily insert a pair of 24r resistors?
regards Andrew T. |
#5 |
Hi Andrew
Could you remove the 50r pot and temporarily insert a pair of 24r resistors? Do you mean insert a pair of 24R resistors and connect both to the S pins of Q1 & Q2? If so where should I connect the D pin of Q3. Please advice. Thanks |
#6 |
CCS drain to junction of the two source resistors. All I'm suggesting is removing the adjustable source resistors and replacing them with fixed resistors. That allows you to take useful measurements.
regards Andrew T. |
#7 |
First off, what do you have the inputs and outputs connected to?
Do you have a FEEDBACK resistor present? A resistor to GROUND at one of the inputs? The circuit might benefit from the addition of a jfet current mirror on top of the LTP... fwiw. The Idss of the 2SJ74 (did you find a source for the exact part numbers? curious about that) in the second stage should likely be higher than the Idss of the 2SK170. That way the 170 will control the quiescent current of the 74. If it is the other way, the lower device will have little effect... Looking at the circuit, the voltage wrt ground on either side of R3 should be about equal and close to ground... that creates slight bias and drive for the ouput devices... The +20vdc tells you which way your circuit is being "pulled." Then look for the source of the driving voltage back in the circuit. If you disconnect the gate of the 2SJ74 in the second stage, the output should be low in DC offset... The current through the upper JFET, and the lower Jfet in the second stage by definition need to be about equal - the input pair provides the reference voltage to the upper JFET, there's a clue. Of course, the opamp needs to be referenced to ground and have loop feedback first. _-_-bear
_-_-bear http://www.bearlabs.com ...ur feeback please - like/dislike my what I have written? PM/email tnx. -- |
#8 |
Hi bear,
1. I have a 10R resistor connected to the +input (R9 at the circuit). 2. I use 2SK170BL & 2SJ74BL JFets. Is this pair good enough for this circuit? 3. Voltage at both sides of R3 is +22V. 4. Which point should I measure to get the reading of the current of the upper and lower JFets in the second stage? 5. Attached is the input/output schematic I used for this OP Amp. Sorry for my question as I do not familiar with electronic theory. |
#9 | |
Connect BOTH inputs to ground for testing, since this is a differential input, single ended output circuit. |
#10 |
C18 is series connected regarding feedback loop, so negative feedback won't be able to correct any DC errors on ouput, becouse C18 will pass thru AC signal only. Correct me if I'm wrong...
Non é mai abbastanza... |
| Jfet BOZ | Vix | Pass Labs | 1125 | Yesterday 03:18 PM |
| Can I replace BF245C JFET with J201 JFET? | bigmike216 | Parts | 2 | 7th December 2005 06:50 AM |
| JFET and ZEN | Skorpio | Pass Labs | 1 | 6th December 2005 09:30 PM |
| Page generated in 0.10720 seconds (84.64% PHP - 15.36% MySQL) with 11 queries |
