Help me find a Mosfet/Transistor amp project useing what I have available??
Old 4th May 2007, 05:41 PM   #1
Minion is offline Minion  Canada
Default Help me find a Mosfet/Transistor amp project useing what I have available??
Hi Folks, I asked a simular question a couple weeks ago but I was looking for a Low power Transistor amp and with the help of some of the members here and was able to Build a aprox 20w transistor amp useing a Tip41/42 and a BC550/560 and an OPA627 and had an all Fet Preamp stage and the pelimary tests on this simple design are encourageing.......
But now I have gotten some more transistors and some Mosfets which I would like to use to build a Higher powered amp but I can"t find a design that uses the parts I have available so that Is why I am here asking you guys ......
So here are some of the Parts I have available:
Power
IRF630 N-Ch Mosfet (200v 9A ) 10 Pieces
RFP8P08 P-Ch Mosfet (80v 8A) 10 Pieces
MJE3055 NPN (60v 10A) 10 Pieces
MJE2955 PNP (-60 10A) 10 Pieces
Tip125 Darlington PNP (-60v 5A) 5 Pieces
Tip 41C/42C NPN/PNP (100v 10A) 1 each
Tip30C/31C NPN/PNP 1 each
Small signal
2N4401/2n4403 Lots
2n3904/2n3906 Lots
BC550/BC560 a few
2N2222 Lots
Opamps (IC"s)
NE5532
OPA134
TL072
OPA602
OPA627
OPA2277
LM3886
LA6324
JRC 5719
JRC 5005
INA103
INA217
XFormers (Power)
2 x 28v 200vA
2 x 18v 100vA
For me it is OK if there are Opamps in the design as it worked out for my Last Transistor amp and it doesn"t need to be High fi and I don"t mind Paralelling several devices.......
If anyone has any suggestions I would love to hear them.......
Thanx a Lot Guys & Gals......
Cheers
Old 5th May 2007, 02:00 AM   #2
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
Sounds like only mid power stuff can be build based on what you have.
Old 5th May 2007, 06:03 PM   #3
Well I"m not looking for a 500w amp or anything Maybe 50w to 100w Max....
I was hopeing to use the 2x28v 200vA Transformer for the PSU (2x40v DC) which I"m sure could only power a 50w or maybe 75w Transistor/Mosfet amp.......
Anything in this Power range would be Good , I would be useing it as the Power stage for a Guitar or bass amp and I would have a seperate High Gain Preamp which will have at least 5v-7v of output......
Can someone point me in the Right Direction.??......
Thanx
PS: the Amp I just built produces 30w into 4 ohms or 18w into 8 ohms useing a Single Tip41/42(10A at 100V) and a single BC550C/560C and an Opa627 and a 50vA PSU so I"m sure it should be Possible to Paralell a few IRFP630 9A 200v devices to get close to 75w useing a 200vA transformer or Paralell several Tip3055/2955(10A 60v) to get simular power???
Old 6th May 2007, 02:06 AM   #4
redrabbit is offline redrabbit  Isle of Man
redrabbit's Avatar
How about these ?
I have not built either one.
I am not qualified to know if used as guitar amp though..??
ESP's Death of Zen
http://sound.westhost.com/project36.htm
JLH Main Page....
http://www.tcaas.btinternet.co.uk/index-1.htm
The JLH classA...
http://www.tcaas.btinternet.co.uk/jlh1996.pdf
Part substitutes....
http://www.tcaas.btinternet.co.uk/jlhtrans.htm
=RR=
Old 6th May 2007, 05:39 PM   #5
Thanx But none of them are Suitable.......
Anyone have any other Ideas??
Old 6th May 2007, 06:11 PM   #6
sixtek is offline sixtek
sixtek's Avatar
What about the ST151?
With 2×28V/200VA transformer in the PSU and using MJE2955/MJE3055s (3 pair pair module - 'cause of SOA). Of course you'll need to check Vceo0 of MJE's. At least 80V needed.
Old 6th May 2007, 06:12 PM   #7
sixtek's Avatar
The schematic
Old 6th May 2007, 06:13 PM   #8
sixtek's Avatar
The PCB
Old 6th May 2007, 06:14 PM   #9
sixtek's Avatar
The parts placing
Old 7th May 2007, 08:56 AM   #10
gmphadte is offline gmphadte  India
ETI 480, 50W into 8 ohms
Help me find a Mosfet/Transistor amp project useing what I have available??Hide this!Advertise here!
Please help me find missing transistor... Bad silver Car Audio 21 25th August 2017 04:36 PM
Looking For a Discrete 50w+amp Project useing Parts I have??? Minion Solid State 9 11th June 2007 08:14 PM
Hard to find transistor... pflodin Solid State 22 21st December 2006 06:46 AM
Hard to find transistor... pflodin Parts 2 2nd August 2004 07:33 AM
