Old 4th May 2007, 02:02 AM   #1
jaycee is offline jaycee  United Kingdom
Default Wierd ALPS motorised Pot
I pulled this thing out of a Pioneer XR-P250 stereo system that the neighbour threw away when the CD player quit. I was planning to use it in my amp and figured it would just be an ALPS motorised pot (it looks similar to an RK168)
However when I measured the pins, it didn't correspond to any of the dual pots ALPS seem to have data on. It also had some wierd connections in the original Pioneer. Here is a rough idea of how one channel was connected:
I measured the following:
Between 7 and 3 = 84K
Between 8 and 3 = 42K
Between 8 and 7 = 42K
Between 2 and 8 = 42K->0->42K (turning CW)
Between 2 and 7 = 84K->0 (turning CW)
Between 2 and 3 = 0->84K (turning CW)
Obviously I could just use the normal connections (2, 3 and 7) but 84K is a little high for a volume pot. I'm also intrigued as to how this arrangement is supposed to work. The pot was mounted on an individual board containing the pot, H-bridge IC, preamp based around a 4558, and muting transistors.
edit: The code sticker on the pot says
ACX7003-A
506t
Old 4th May 2007, 02:15 AM   #2
Sonusthree's Avatar
Does it have some kind of 'loudness' control built in for low volumes?
Just a guess
Old 4th May 2007, 02:29 AM   #3
That was what I was thinking.. but 42K-0-42K thing coupled with what appears to be a filter makes me think its some kind of trick to keep the impedance constant across the whole range of the control.
Old 4th May 2007, 04:47 AM   #4
It has seven connections...
then it is a dual stereo pot with loudness connection.
What confuses is the ground connection and is shorted internally for both the pots.
Gajanan Phadte
Old 4th May 2007, 05:25 AM   #5
Cool, I get it now.
Just wondering how best to use this. Obviously, I don't want a "loudness" circuit in my hi-fi amp altering the sound!
looking at this helps. Hm, according to tests, this is a linear pot.
-Possible Trade- 2ch motorised alps pot for 4ch matt09 Swap Meet 1 28th June 2009 12:19 AM
motorised faders fanjita Parts 2 12th December 2006 04:19 PM
Motorised pot hugobors Parts 4 3rd February 2006 12:15 AM
FS: Alps RK27 motorised volume pot with remote controller PCB ready to fit in amp rabbitz Swap Meet 3 8th September 2004 03:09 PM
motorised potentiometer trancy Parts 0 11th March 2004 06:03 AM
Page generated in 0.07425 seconds (75.09% PHP - 24.91% MySQL) with 11 queries
