HI
S41775, S41776 ,SJ6207,SJ6206-I M LOOK THIS TRANSISTORS -TRANSISTORS BOOK AND NET THIS TRANSISTORS I CANT FIND ANYWHERE ,THIS IS MARANTZ MODEL 510M TRANSISTORS HAVE THIS TRANSISTORS ANOTHER NUMBER OR WHAT IS THE STANDART NUMBER?and WHICH TRANSISTORS FIT TO THIS POWER AMP ? PLEASE HELP THANKS GUROL:bigeyes: |
#2 |
Fairchild and Motorola devices, although Marantz amps were already produced in Japan at the time of the 510M.
replacements: here (fairy tale time: story goes that the fan operated heat duct setup of the 510M was developed by NASA)
Looks like Sponge Bob has killed another thread. |
#3 |
HI
THANKS THE MAIL I M NOT UNDERSTAND THE TRANSISTORS LINK PLEASE SEND ME ANSWER WHICH MODEL POWER TRANSISTORS FIT TO MARANTZ 510M POWER AMP? THANKS GUROL |
#4 |
HI
S41775, S41776 ,SJ6207,SJ6206-I M LOOK THIS TRANSISTORS -TRANSISTORS BOOK AND NET THIS TRANSISTORS I CANT FIND ANYWHERE ,THIS IS MARANTZ MODEL 510M TRANSISTORS HAVE THIS TRANSISTORS ANOTHER NUMBER OR WHAT IS THE STANDART NUMBER?and WHICH TRANSISTORS FIT TO THIS POWER AMP ? PLEASE HELP THANKS GUROL |
#5 |
Speakerholic
Hi Gurol,
I gave your post it's own thread because it didn't belong in someone else's. I can't help with the transistors but I will ask that you turn the caps lock button off. It looks like you're yelling. |
#6 |
HI
WHICH MODEL TRANSISTORS FIT TO THIS S41775 -? S41776 -? SJ6207 -? SJ6206-? RCA41C-? RCA42C-? Thanks Gurol |
#7 |
HI
I FIND WHICH POWER TRANSISTORS CAN replacements TO MARANTZ 510M POWER AMP Thanks Gurol. My e-bay name is : naac.tr |
#8 |
AFAIK
Outputs are 2N6031, 2N5631. Drivers are 2N3584, 2N6421.
Candidates for the Darwin Award should not read this author. |
#9 |
Hello From Turkey
I use the marantz 510m amp power trasistors:2SD424 & 2SB554 and the driver transistors MJE15031 & MJE15032 Work perfectly ! The sound is the same 510m orginal transistors !!!!!! Thanks -Gurol |
| Marantz 510M Power Amplifier | pkgum | Solid State | 3 | 16th February 2009 08:02 PM |
| Marantz 510m Resurection | sound_prodigy | Solid State | 22 | 6th October 2007 10:12 PM |
| service a marantz 510m in SE QLD | El_Hefty | Solid State | 1 | 8th December 2006 04:46 PM |
| Page generated in 0.09707 seconds (76.25% PHP - 23.75% MySQL) with 11 queries |
