I am simulating a basic three stage audio amplifier in the full version of TopSpice, mainly to experiment with using a DC servo in the feedback loop to nullify the output offset.
The DC servo itself is a basic opamp in the integrator configuration (input R at 10k, feedback C of 100n). My current problem is this: When I simulate the circuit to get a DC bias point using an ideal opamp (a VCVS with gain = 999,999), the output offset voltage is in the uV (great!). When I replace the ideal VCVS with a spice model LF411 or LTC1151 opamp, the output bias point rails either high or low. Now I understand that the opamp models have important features and parasitics modeled into them, but I wouldn't *think* that it such parameters would make such a big difference (I was hoping to get an offset of at least a few mV, not -99V!). ==> Any ideas as to what I could be doing wrong or overlooking? |
#2 |
Op-amp input phase reversal at overdriven input maybe...
Antiparallel diodes at input of an op-amp do the trick. |
#3 | |
The original RC values you specified (10K, 100 nf) yield a time constant of 6.3e-3, which is well within the audio range. You want the time constant of the servo to be well below 1/20 Hz (50 ms) . Otherwise the servo amp will act as a lowpass filter and remove audio content. When running SPICE, remember to simulate for a long enough time to observe the RC time constant of the servo amp. For the values I gave, this is on the order of 1 second.
JCM |
#4 |
==> When running SPICE, remember to simulate for a long enough time to observe the RC time constant of the servo amp. For the values I gave, this is on the order of 1 second.
Aha! So you are saying that I should run a transient simulation to determine if the dc servo is setting the right bias point, not just an .OP simulation? |
#5 | |
JCM |
| Need some help with simulation | guitvinny | Tubes / Valves | 4 | 12th January 2008 12:33 AM |
| OB simulation | augerpro | Multi-Way | 10 | 4th June 2007 12:17 AM |
| How to minimize output offset drift w/o servo?? | Leolabs | Solid State | 14 | 10th November 2006 01:27 PM |
| MJK Offset Driver simulation with PL-18 Help | JC Fardo | Multi-Way | 7 | 20th June 2004 06:28 PM |
| Servo for correcting DC offset and drift | alaskanaudio | Solid State | 3 | 17th November 2001 10:36 AM |
| Page generated in 0.09612 seconds (74.95% PHP - 25.05% MySQL) with 10 queries |
