diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Solid State (http://www.diyaudio.com/forums/solid-state/)
-   -   Sanken SAP devices vs. normal LAPT singles (http://www.diyaudio.com/forums/solid-state/101130-sanken-sap-devices-vs-normal-lapt-singles.html)
capslock 2nd May 2007 03:19 PM
2 Attachment(s)
Those Sanken SAP devices are found in a surprising number of commercial receivers. After all, they are darlington pairs with built-in temperature compensation, which saves mounting up to three extra devices to the heat sink.
Interestingly, the Sanken data sheets give to f_t information on the SAP devices and they do not say whether the multi-emitter (LAPT) technology is used.
Looking at h_FE vs. I_C for an LAPT and an SAP device, I would assume not:
capslock 2nd May 2007 03:25 PM
2 Attachment(s)
The other problem with those devices is that the emitter resistor of the driver is hard wired to the integrated emitter resistor of the output transistor.
This means that there is no way for the active transistor to draw charge out of the base of the inactive transistor.
Reading the app note, for currents well in excess of the specified I_C at low V_CE, the integrated emitter resistor should fail before the transistor. From the equivalent circuit, it would seem that discharging a medium sized electrolytic through the E and S terminals would do the job without having to test the limits of the transistor chip. Let's hope it is really the resistor that blows and not the bond wire. If so, a new emitter resistor could be connected to the S terminal, and the 100 R resistor of the driver would be accessible through the E terminal.
Leolabs 3rd May 2007 01:51 AM
The subject should be"normal BJT versus darlington"???
capslock 3rd May 2007 04:57 AM
Not really, it is specifically SAP darlington vs. a decent discrete double emitter follower with extended h_fe curve drivers and output devices.
capslock 3rd May 2007 08:48 AM
Darlingtons have two problems:
1. They offer no access to the emitter of the driver - I explained above how this might be overcome in the SAP devices.
2. There are no extended beta darlintons around (if there are, please point me to them). I had some hope the SAPs might be, but from the curves I doubt that.
jaycee 4th May 2007 01:42 AM
I think that the SAP's are merely designed to be compact robust devices for 5.1 amps and suchlike, where space is important. Obviously, there are compromises.
Having said that, I have heard an Arcam DiVA A80 based around these devices, and i have to say the sound was excellent. The amp, if i remember rightly, was based on an opamp frontend using current feedback, driving the darlingtons through pre-drivers, effectively forming a triple.
Resources saved on this page: MySQL 18.75%
