Old 1st May 2007, 10:34 AM   #1
EchoWars's Avatar
Default Thermal Cut-off Temperature for a VFET
Have a Sony TA-4650 integrated VFET amp, with a blown PTC thermistor (PTH401 on the schematic). I've no idea at what temperature that the original is supposed to operate. Got choices of 30°C to 110°C, and was thinking that 60°C ought to be reasonably close to a proper temperature to disconnect the load.
Think that's too hot?
Old 1st May 2007, 11:25 AM   #2
Workhorse's Avatar
Send a message via Yahoo to Workhorse
Default Re: Thermal Cut-off Temperature for a VFET
85°C PTC
Old 1st May 2007, 09:13 PM   #3
EchoWars's Avatar
Is that a guess, or is there a reason to pick that temperature?
Old 2nd May 2007, 01:15 AM   #4
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
Where is the PTC located(stick to what material)???
Old 2nd May 2007, 02:58 AM   #5
EchoWars's Avatar
PTC is screwed to the output transistor heatsink. Guess I didn't make that clear in my first post.
Old 2nd May 2007, 11:25 PM   #6
EchoWars's Avatar
Hmmm...thought this would be an easy subject. 100+ views, 1 terse reply, 1 question.
Thermal devices have been around for years...most amps with fans have a switch to start the fan at about 70°C, so obviously semiconductor destruction isn't going to happen at that temp. I was simply hoping that someone might have some experiance with maximum safe operating temperatures for power devices.
Talking to myself again...I'll toss a 70°C PTC in there (tolerance on the only ones I can find is +/-7°C) and call it a day.
Biasing/thermal compensation of Thermal Trak transistors Bob Cordell Solid State 156 11th December 2010 08:38 PM
Sony Vfet housing Solid State 3 11th April 2009 12:14 PM
help with Thermal Impdeance vs. Thermal Conductivity Eric Pass Labs 4 22nd July 2005 07:23 PM
Page generated in 0.08090 seconds (72.07% PHP - 27.93% MySQL) with 10 queries
