Old 30th April 2007, 10:41 AM   #1
covik is offline covik  Croatia
Default Class A sigle ended Help?
I found this schematic on the net, im curious to build it.
Can someone explain if it works, maybe someone build it,
is the schematic ok, will bias current blow my speakers,
i dont know, im lost, but it is very interesting 12Volts 16W class A.
The link to the page is not working.
Thanks!
Old 30th April 2007, 03:17 PM   #2
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
Theoritically it will work.Don't worry that bias current will blow you speaker as there is a output cap.
Old 30th April 2007, 04:27 PM   #3
flg is offline flg  United States
flg's Avatar
That .5H L is likely to weigh 1/2 as much as your car battery
Old 30th April 2007, 04:39 PM   #4
Will half a henry cost ten times as much as a car battery?
But, if it doubles the output swing from it's stored energy it could be worth it. Yes, four times the power compared to the normal output swing of a single ended.
Is that much extra achievable?
regards Andrew T.
Old 30th April 2007, 04:47 PM   #5
HOEK is offline HOEK  Netherlands
Hello
Will this amp work on 24V dc
regards
Old 30th April 2007, 05:42 PM   #6
Hello
regards
Old 1st May 2007, 01:43 AM   #7
Send a message via AIM to ThSpeakerDude88
wow.. I am quite interested in this as well, as most decent decks put out around 16 watts RMS anyways...
That choke might be hard to find though, at the amperage it needs to handle
always preach the gospel-
and when necessary use words.
Need Tube kits of above 75W Single Ended Class A amp pokerking Tubes / Valves 25 11th July 2009 05:19 AM
Compact Single-Ended Class A Build inspiribomb Pass Labs 32 26th January 2009 02:57 AM
push pull Vs single ended class A amp space2000 Solid State 25 23rd August 2008 03:31 PM
class A single ended darkfenriz Solid State 16 21st January 2005 07:22 AM
Page generated in 0.09029 seconds (72.46% PHP - 27.54% MySQL) with 11 queries
