Perreaux 9000B schematic?
Old 29th July 2012, 03:54 AM   #31
still4given is offline still4given  United States
still4given's Avatar
I'll give it a try tomorrow. Can't really get to it today.
So you think the bad MOSFET is lurking in the p channel not the p-?
Old 29th July 2012, 04:59 AM   #32
Another thought, if there is no current across gate resisters, how can they be drawing the voltage down?
Old 29th July 2012, 06:58 AM   #33
srh is offline srh  New Zealand
Hi Terry, the gate current check is not a definitive one. It is just one of a number of tests that can be done before you have to pull the fets and test them on a jig. Don't forget to check the diodes D3, ZD2 for faults. It is difficult to troubleshoot using only a dmm when there are no major discrepancies in the voltage readings. There is no substitute for a dummy load, a signal source and a scope when it comes to fixing amps ime. As I have suggested previously, running it under load and watching the waveform symmetry is the easiest way of seeing if all the fets are functioning.
Steve.
The older I get, the more simplicity appeals.
Old 29th July 2012, 07:05 AM   #34
Nrik is offline Nrik  Denmark
Originally Posted by still4given View Post
Ok, I adjusted the bias until the P- side came up to 0.424V but now the P+ is 0.528. Also, the output offset is now +032mv
thanks
32mV offset is not a problem.
Try to listening to it in this state before pulling MOSFETs.
Henrik
Old 29th July 2012, 04:02 PM   #35
Ok, I'm still trying to understand where the voltage at RV1 is coming from.
1) Does it come from the collectors of Q4 and Q5? If so, could a fault in Q3, Q4 or Q5 cause the voltages to be off?
2) What is the function of D3-ZD1?
3) The Schematic calls for 0.6V across RV1. The good channel was set at 0.8V when I got it and it plays fine. Is this due to the higher rail voltage?
Thanks, Terry
Old 29th July 2012, 07:49 PM   #36
Thanks, Terry
1) Yes - the voltage comes from the current generated by Q4 and Q5, and the current through Q5 is created by Q3. So technically speaking - yes a faulty transistor in one of these positions would of course be a bad thing...as well as faulty transistors in Q1 and Q2 since they also influence the current through Q3 and Q4. However it is not likely that any of those are defective.
By looking at you measurements in post #7 both channels looks quite balanced and should work. Of course there is a difference of some 7-8Volt some places, but remember that the supply lines are at 117Volt each ... that is less than 10% meaning it is probably just component tolerances and age. Without an osciloscope and sinus generator to prove differently it is hard to think that any of these transistors should have gone.
Tolerances and age is probably also the reason why the voltage over VR1 has moved below the safe MOSFET-on-state base-source voltage-drop, starving the output stage and resulting in a true class B performance with lots of crossover-distortion. You should really just give the VR1 one notch more until the MOSFETs are conducting safely, and the sweet sound exits at the speaker terminal.
2) D3 - ZD1 are there to protect the bases of the MOSFETs for voltages over 10V between base and source, wich could destroy them.
3) The higher the voltage over VR1 - the higher the idle current through the MOSFETs. As I recall it (hard to find the datasheets) 0.7-1.0 volt seems right for these audio MOSFET pairs. Now that you can't measure the idle current then you can maybe feel how warm the heatsink gets in the two channels. I bet the good channel gets warmer - because it carries the 170mA more or less, whereas the bad channel will be as cold as the cabinet because no current is running through the output. If that is indeed the case, then that is another proof that you can safely adjust VR1 a little up.
Henrik
Old 29th July 2012, 11:58 PM   #37
Thanks for the great explanation! I have a much better grasp on it now. I ordered a sinewave generator and will get the scope out and see if I can remember how to hook it up. Turned up the bias to get the p- to .424. I was going to give it a listen but can' find my XLR adapters. After I do I'll report back to how it sounds.
Still, it seems suspicious that an amp that played beautifully for years just all of a sudden goes to distortion in one channel without some kind of component failure.
Thanks again, Terry
Old 30th July 2012, 06:00 AM   #38
Great.
Looking forward to read about your measurements.
By the way: The schematic shows some fuses in the supply lines. It is a bit strange that there are none in real life.
But for the final adjustments it would be nice to be able to measure the idle current somehow.
Would you be able to insert a 0.1 ohm/5W resistor in one of the supply lines?
Henrik
Old 30th July 2012, 08:25 AM   #39
Yeah, after looking more closely, those fuses are in sockets on the rear panel. I can probably rig up a resistor using clips. When I get everything ready I will get back to you.
Thanks, Terry
Perreaux 9000B schematic?Hide this!Advertise here!
Perreaux 6200B Schematic Required fullcircle Parts 2 29th July 2009 04:25 AM
Looking for Perreaux SXV1 schematic lumanauw Solid State 0 28th March 2007 12:15 PM
Perreaux PMF 2000 Schematic wanted musicrepairs Solid State 0 5th January 2007 11:54 PM
Anyone Perreaux PE preamp schematic? stavros Solid State 0 19th April 2006 05:46 AM
Looking for Schematic Perreaux SXH1 Headphone Amp. Franklin Headphone Systems 0 23rd December 2004 06:16 AM
