Old 13th March 2004, 02:25 AM   #21
sam9 is offline sam9  United States
sam9's Avatar
Going back to the original question, I think the mostb significant reason is habit and familiarity with a particular orientation in the schematic. If you learn about the subject from schematics showing it in a particular orientation you are likely just to continue the pratice.
I, too tried to see if Space gave any insight, I even tried combining each orientation with quasi-complementat outputs of each orentation for a total of four permutations. ( A waste of a rainy afternnon with nothing else to do!) There were no differences that effected significant digits.
This suggests a scheme to charge exorbitant sums in the high-end market: build and amp with R & L channels topologicaly inverse from one another and attribute magical properties to the concept. "Right vs. Left is an outdated Eurocentric concept, we should really be concerned with Yin and Yang channels . . . ."
Old 13th March 2004, 03:03 AM   #22
a31_ford's Avatar
Off Topic> "Medical Equipment"
Even when I said "don't go there"
In a nutshell, I have been told that NPN is more coudusive to being used in enviroments around the human body.
(Somthing about bio-feedback induced nano-currents, from ground loops when using PNP devices).
Remember, the electronic probes used on humans are MORE sensitive that an LNA / LNB in a satilite dish.
Greg, aka A31Ford
Manitoba, Canada
Old 13th March 2004, 05:01 AM   #23
The one and only
Nelson Pass's Avatar
Dimitri, be nice.
A lot of people have awaited the return of Halojoy, enignmatic
as his posts might be.
Elso Kwak has not disappeared at length, but he enjoys similar
affection.
Remember this is the entertainment industry. (Personally I
am waiting for Asia Carrera, Mensa member, to take an interest
in hi-fi and climb in here). We could use a non-male viewpoint.
Anyway, I think that PNP's were and are popular because the
original RCA manual used them that way, and they remain
vestigial design items, like output coils.
Cheers, as Goldfrapp says.
Old 13th March 2004, 05:47 AM   #24
I seem to recall that Raquel Welch is reputed to have a fully operational brain too, although Asia Carrera has the advantage in years, at least at this point.
Grey
Old 13th March 2004, 08:41 AM   #25
traderbam's Avatar
As early as in the seventies I remember a French designer claiming that complementary transistors never could be complementary.
These French - always refusing to follow the herd, instead sticking to UNpopular principles.
Ok so who told the French that electricity itself is asymmetrical? Who gave it away? The fact that electrons and holes are not opposites was supposed to be a secret. What do you mean they worked it out for themselves?
Hey, what do ya know, these gents aren't just about brie and accordions after all!
Old 13th March 2004, 10:05 PM   #26
Electrons are from Mars, holes are from Venus!
Old 13th March 2004, 10:33 PM   #27
The one and only
I'm going to mark this in red on my calendar:
*** John Curl makes joke ***
Old 13th March 2004, 10:42 PM   #28
Maybe we should try to do designs that use both matter and
anti-matter? Then we would have a perfect symmetry between
electrons and positrons. There will be some slight techincal
problems to make it safe and functional, perhaps, but on the
other hand, we probably won't need any external power source.
Come to think of it, maybe it will even be self-soldering.
Old 13th March 2004, 11:30 PM   #29
The one and only
I've always wanted to play with a P type tube.
Old 13th March 2004, 11:41 PM   #30
ingvar ahlberg's Avatar
Its exactly the same as a 6L6G but with the vacuum on the outside and the cat inside.
Ingvar
Adding a third input to a differential input stage? maudio Solid State 15 11th October 2006 02:16 AM
current bias j-fet input 2sk170 ,2sj74 at input stage YUTK Solid State 11 2nd June 2005 03:34 AM
input cap at D1 I/U stage Klaus Pass Labs 3 30th December 2003 11:00 AM
Input stage Andrey Solid State 5 21st June 2002 01:32 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
