Current Yamaha AV receivers (RX-V 559): what kind of output stage?
Old 24th April 2007, 04:15 PM   #1
capslock is offline capslock  Europe
Default Current Yamaha AV receivers (RX-V 559): what kind of output stage?
What kind of output stage and DAC does Yamaha currently use?
I peaked into an RX-V 459 and 559, and from what I could see through the lid, they are using 5 pin ICs. These could be real ICs or transistors with built-in bias diodes. Anybody know?
Also, there was an SSOP28 chip with the BB label, but I couldn't read the model. I assume that was the ADC, as they'd surely use an 8 channel DAC.
Background is that I need a cheap base for a 3-way active XO, and I like to modify my DACs and output stages.
Old 24th April 2007, 09:09 PM   #2
jaycee is offline jaycee  United Kingdom
Probably Sanken SAP output devices, in which case the output is most likely an EF stage.
Old 25th April 2007, 01:30 AM   #3
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
Search for the service manual of them might help.
Old 26th April 2007, 04:24 AM   #4
Yes. if I had found a service manual on the web, I wouldn't have asked.
I also thought that those were SAP devices, except the writing on the PCB said ICxxx. I couldn't read the writing on the thingies themselves, unfortunately.
Current Yamaha AV receivers (RX-V 559): what kind of output stage?Hide this!Advertise here!
UcD output stage current sensing zilog Class D 20 6th November 2006 08:04 AM
Floating current source in cascoded output stage rtarbell Pass Labs 0 7th April 2006 01:46 AM
kind suggestion for an high current buffer. beppe61 Solid State 11 15th October 2005 06:36 PM
input stage current required to drive output mosfets? AudioGeek Solid State 6 22nd May 2005 04:05 PM
Yamaha RX-V530? AV-Receivers? weissi Solid State 2 16th September 2003 02:47 PM
Copyright ©1999-2017 diyAudio
