want to take audio signal from PC sound card..
It's gain should be flat from 30Hz To 22KHz.. Low noise.. Neeed improvement?? Thread on other WEB Thanks. |
#2 |
R2 is superfluous. Divide R3, R4 by 10 for lower noise.
Divide pot by 10 for lower noise. I think your gain is too high for sound card into power amp. What's the sound card output level? Jan Didden
/Another new issue: Linear Audio Volume 3! |
#3 |
If i divide all resistor by 10 then
VR1 = 10k R1 = 1K R2 = 100K R3 = 1K R4 = 6.2K AND C1 should be equal to 4.7uF for flat responce down to 30 Hz. Which type of capacitor(C1 = 4.7uF) i should use for goodresult?? I am assuming Output of sound card is 200mVolts and this circuit have Gain of 7. Thanks for reply. |
#4 |
Electrons are yellow and more is better!
Have investigated how much the output voltage is? Probably more than 200 mV.
/Per-Anders (my first name) or P-A as my friends call me |
#5 | |
#6 | |
OK I see what you mean, but in my book, the only right thing is to replace the pot . No scratchy pots in my hifi!Jan Didden
#7 | |
R1 was ok as it was. Yes 4.7u seems OK. a good foil cap would do. Many will advise 100$ designer caps, but that's your taste. I would think sound card output is 1 to 2 V. Google the brand/type and look it up to be sure. Jan Didden
#8 |
If the source is a soundcard, you know that it will be capacitively coupled already, so there is no need at all for C1.
I can think of about a 100 better op amps than a TL071. The size of the resistors probably doesn't matter that much in this circuit since the input level is high. Johnson noise is probably irrelevant. I would still scale down the resistors however as recommended. If nothing else, it minimizes the effects of stray C. If the resistors are relatively small, you can consider a BJT input op amp as an alternative. You may not need an output C either if the input offsets are reasonably low. You don't show power supply details. Make sure you decouple the op amp properly. Al Clark |
#9 |
| have anyone make th HIGH QUALITY AUDIO MIXER | darkwind_j | Solid State | 1 | 29th July 2009 02:59 PM |
| have anyone make th HIGH QUALITY AUDIO MIXER | darkwind_j | Parts | 0 | 28th July 2009 01:58 PM |
| high-quality single-rail mic preamp? | slothlove | Instruments and Amps | 2 | 17th June 2008 03:48 PM |
| High Quality Mic Preamp? | sopapo | Solid State | 7 | 13th October 2005 03:36 AM |
| IC High Quality Mic Preamp | xanduy | Chip Amps | 0 | 17th March 2004 05:54 PM |
| Page generated in 0.10775 seconds (78.78% PHP - 21.22% MySQL) with 10 queries |
