I got a vintage Forte Model 5 power amp used. It is a nice sounding amp, but is plagued with a constant, low level HUMMM which is just audible from my listening chair when the room is very quiet. I understand hum modulates/distorts the music which is undesirable. I've checked all cable/cord grounds.
My speakers are an MTM design with 90dB sensitivity (the other owner used Magnapans and didn't notice the hum). The amp uses a toroidal power transformer and input signal wires are shielded & routed carefully to the rear, away from the power supply components (see pic.) The hum occurs even when the inputs are shorted/disconnected and when the power amp is the ONLY component used (i.e. everything else except speakers was unplugged) it appears to be within the power amp itself. Unfortunately there is no balanced option in my system, as all components use single-ended RCA. Any ideas/suggestions to combat this hum? |
#2 |
If it is both channels--start looking at the power supply filter caps.If its in one channel or the other you have a small bypass cap causing the humm.
Dave
Ret. USAF... AKA- Avionic *** Solder slinger for hire...*** |
#3 |
It's in both channels; however, the filter capacitors were replaced recently and they tested good.
Any other ideas (could it be the transformer and if so, what can be done short of replacement)? |
#4 |
Could you post a closer detailed pix of the powersupply rectifiers or bridged rectifier....I'm thinking possibly a noisy rectifier.
#5 |
Rectifier bridge was also replaced- still hums.
#6 |
Here's a closeup of inputs and rectifier.
#7 | |
I dont think your transformer is the problem.Have a read of this article.It may help. Dave
#8 |
I think you connected ground via this metal tab wrong way.
You created a closed loop of chassis/transformer center screw/ ground tab so that it forms an additional secondary winding and adds hum to ground. My advice is connect reservoir capacitors to each other different way, not by metal tab connected to transformer screw, use just a piece of wire instead. |
#9 | |
#10 | |
Dave
| 40A 250V Schottky Power Diodes- Has anyone use in Power Amp to replace Diode Bridge? | dtm1962 | Solid State | 10 | 15th September 2011 07:38 PM |
| smps power sg3525 for 3000 wats power alimentation | MARAVILLASAUDIO | Car Audio | 2 | 24th February 2005 06:58 AM |
| selling high current power supply for power amps. | ericpeters | Swap Meet | 0 | 14th January 2005 02:21 PM |
| Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality | MARAVILLASAUDIO | Class D | 1 | 5th November 2004 04:06 PM |
| power output calculations, rated power and required power output | metebalci | Tubes / Valves | 7 | 22nd February 2004 05:49 PM |
| Page generated in 0.10817 seconds (77.15% PHP - 22.85% MySQL) with 11 queries |
