input impedance - diyAudio
Old 17th January 2003, 03:31 PM   #1
Default input impedance
I'm designing a phono stage to be coupled with a solid state integrated amplifier. Can somebody provide me some indication about the typical input impedance and voltage sensibility of this kind of amplifiers?
Thank you
Old 17th January 2003, 05:07 PM   #2
halojoy is offline halojoy  Sweden
On Hiatus
Default Re: input impedance
Thank you
An integrated amplifier's input goes to the Preamp-part
of the integrated.
For the normal input. CD AUX and so,
it is usual to find INPUT-impedance of 47 kohms
It is like a standard.
But variations can be between 100kohms downto 22kohms.
Sensitivity for full Power Output
can be like 0.5 Vrms. Can be 0.2-1.0 for some.
Best is if you can find
Technical Specifications and Data for Your amplifier.
This you can often find by searching the Webb,
and you can find it in The User Manual, which also sometimes can be found on the Web, for download.
Mostly as a PDF-file.
Power Amplifiers - Output Stages, without preamps
usually have lower input impedance (5kohm)-10kohm-22kohm
and sensitivity like 1.0-1.4 Vrms.
The job of the preamp is the make sure that the Power Amplifier
gets that level and to be sure that lower impedance can be driven.
(this above goes for Solid State. Tube amplifiers is special case.
They can be very individual in this respect.)
/halojoy
Old 17th January 2003, 07:02 PM   #3
Electrons are yellow and more is better!
peranders's Avatar
Your phono stage shall have an output impedance less than 1 kohms. Then the amp can drive anything, even rather long cables. If you use an opamp you can have 220-1000 ohms without no problem. Higher value is safer from short circuit, lower value gives you more drive power but risk for problems with capacitive load (cable capacitance).
If your phono amp has rather low output impedance, it's rather unimportant what the input impedance of the following amp has.
/Per-Anders (my first name) or P-A as my friends call me
PA03 LM4780 amplifier group buy, SIGN UP HERE for the group buy 0 boards left. 118 paid.
Input Impedance Bengali Analog Line Level 7 15th August 2007 10:24 PM
Input impedance nhuwar Tubes / Valves 24 23rd July 2007 11:11 PM
How much input impedance is enough? Russ White Chip Amps 5 13th April 2005 07:25 PM
input impedance bbksv Chip Amps 2 13th February 2004 11:58 PM
JLH input impedance hlyytine Solid State 12 1st February 2004 07:00 PM
Copyright ©1999-2017 diyAudio
