hi guys, i've found a nice carver m500-t but it's faulty, 4 transistors are blown an i can't see the model of the transistors, does anyone has experience with it?i need at least a schematic to try to repair it...thanx a lot in advance!
#2 |
anyone?maybe someone who knows the transistors inside the amplifier...please!
#3 |
Those transistors are long obsolete, most likely NEC B705 and NEC D745. Carver had a service bulletin to replace them with 2SA1302 (also almost obsolete so use 2SA1943) and 2SC3281 (also almost obsolete so use 2SC5200). The new transistors are a different case style so you will have to get creative when mounting the new transistors. I have used these transistors in a M500 without any problems.
#4 |
thanx a lot mate!but these are final transistors, but on the same heatsink there are also smaller transistors, and they're blown...maybe i'll post a picture asap..do you have a service manual?can you send it to my email?and do you think i have to chack other components?
#5 |
ok, transistors found, but the name i a fabric name! namely
A1111 C2591 how can i know which replacement to use?
| Carver M500-T Unit fuse | other3 | Solid State | 4 | 26th October 2008 09:32 AM |
| Carver M500 power amp start up problems. | AMV8 | Solid State | 7 | 13th May 2008 12:59 PM |
| Carver M500 Power Supply | jpanwell | Solid State | 5 | 27th November 2007 04:56 AM |
| Carver TFM Schematics? | trezza | Solid State | 2 | 9th January 2005 03:20 PM |
| Schematics Carver | leiade | Everything Else | 3 | 7th November 2002 10:06 PM |
| Page generated in 0.32764 seconds (100.00% PHP - 0% MySQL) with 9 queries |
