Old 16th April 2007, 12:02 AM   #1
cotdt is offline cotdt  United States
Send a message via AIM to cotdt
Default Directly driving ribbon tweeters
Transformers cause a lot of distortions, so I would prefer using an amp that can directly drive the low impedance of a ribbon tweeter, without using an output transformer. Who makes such amplifiers?
Old 16th April 2007, 03:39 AM   #2
LineSource's Avatar
cotdt.
A ribbon tweeter will have a DC resistance around 0.05 ohms. You can put a non-inductive resistor of about 0.2 ohms in series, accept the power dissipation loss, and use a solid state amp like a KRELL KMA100 which can drive very low impedance loads. Naturally you can use a 2 ohm non-inductive series resistor and a normal amp and accept a larger power loss.
Read over the KSA 100 MKII clone thread and consider running some Spice using a +/- 5V supply on the output with a 0.1 to 0.25 ohm load.
You can also go to the digital section and read over the TI xx261 digital amp thead and ponder a very low output power supply voltage, a super low impedance MOSFET(or two) and a super thick wire output inductor(or two).
Old 16th April 2007, 06:07 AM   #3
Gold_xyz's Avatar
also you can project an high current - low voltage amplifier only for
tweeters with mosfet very low rds_on.
(With active filter two or tree way amplification)
My English originates from here
UcD400 Driving A 1/2 Ohm Ribbon? valveitude Class D 8 12th November 2010 08:06 PM
Driving Eight IRFP064 with SG3525 directly xyz9915 Power Supplies 3 3rd November 2008 03:27 AM
looking for jvc ribbon tweeters peter.bobrik Multi-Way 5 4th December 2007 03:42 PM
F2 - driving two tweeters Nicola Pass Labs 11 19th December 2006 06:35 PM
Ribbon tweeters in Car? vision Car Audio 4 26th October 2006 11:30 PM
Page generated in 0.06579 seconds (71.94% PHP - 28.06% MySQL) with 10 queries
