my Cyrus pre-amp with PSXr is sending out 100Vdc to 115Vdc on the audio ground line (RCA barrel) when disconnected from the receiver. If I link a 10r to earth the voltage drops to around 0.1mV. Is this normal? I discovered it while investigating the earthing of my Leach. That same 110Vdc was passing through the active crossover and appearing on the Leach audio ground if the disconnecting network was temporarily broken. It sparks (very slightly) if connected while live.
regards Andrew T. |
#2 |
Hi Andrew
![]() You measured 107 VDC with reference to what ? Signal ground ?
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com |
#3 |
Hi Acd,
110Vdc above reference to earth pin on the socket/plug/chassis.
regards Andrew T. |
#4 |
I cann´t recall ......
Do you use Mains earth connection over there ?
#5 |
mains safety earth for all except double insulated. The Cyrus is not double insulated, so the ground voltage is surprising. Gives the impression they really do have a floating audio ground in the pre-amp, or something gone open circuit?
regards Andrew T. |
| normal X-Amp | uli | Pass Labs | 42 | 19th November 2010 06:31 AM |
| denom pma250 amp faulty,but no faulty parts found please help | homertooties | Solid State | 1 | 7th December 2008 03:58 PM |
| WTB Cyrus 1 or Cyrus 2 amplifier | monstertrucker | Swap Meet | 0 | 20th November 2008 01:04 AM |
| Is it normal to think this way? | gain-wire | Instruments and Amps | 3 | 16th October 2008 11:09 PM |
| Cyrus Two - Faulty Speaker Channel | Hedley | Solid State | 0 | 30th January 2008 10:57 PM |
| Page generated in 0.07751 seconds (68.47% PHP - 31.53% MySQL) with 10 queries |
