Old 14th April 2007, 04:57 AM   #1
Ayne is offline Ayne  Pakistan
Default Going to Design (Preamplifier PCB).
After searching enough, i found this
Preamplifier Circuit Page
Then i make them in simulator..
1st CIRCUIT PREAMPLIFIER
2nd CIRCUIT MICPREAMPLIFIER
In simulation their result is enough satisfactory..
But i use TL072 and i have listen that TL07X series is not good enough now a days.
What u suggest, Best OPAMP, Infact i want to connect this Preamplifier with Computer output..
OPAMP Should be dual(two OPAMP in single chip)..
I am asking best OPAMP here because, many expert members are here and i think they have dealed with enough OPAMPs. I want to take advantage from their experience...
I also request to expert members that put ur views about this Preamplifier over here..
After ur Responce i will make PCB of above both circuits..
Thanks.
Old 14th April 2007, 09:23 AM   #2
vynuhl.addict's Avatar
It depends what you are looking for,k best sonics or something that serves its function. The BB opa2134 is a good dual chip, op275, or opa2604. My personal fave which is unsurpassed by any single op amp is the Jung Composite Op Amp or the diamond buffer with a fet input op amp. With some careful choices you can put yourself in a position to be able to eliminate output coupling caps and caps between preamp stages.
Colin
Old 14th April 2007, 10:01 AM   #3
darkfenriz's Avatar
I do not like the mic section, you will have to use huge electrolytic capacitors and PSRR will be poor.
Old 16th April 2007, 01:41 PM   #4
Question Some Questions
Q no 1:- why we listen a sound when we put mic infront of speaker????
Can we minimize that sound.
Q no 2:- What is PSRR???
Please explain above both questions in detial.
Thanks.
Old 16th April 2007, 01:55 PM   #5
sixtek's Avatar
1., the system is "festering"
2., PSSR = power supply rejection ratio
Old 16th April 2007, 02:19 PM   #6
Thanks sixtek.
But i googling with "festering" and found nothing related to Sound and Mic..
Plz can u explain in more detial???
Wilson Watt Puppy Clone Design - Design Review Please soundengine355 Multi-Way 8 15th August 2008 02:07 PM
4th order bandpass, wheel well design :) (design inside) TWOJZ Car Audio 28 13th January 2008 02:56 PM
stereo/sub preamplifier design RHosch Solid State 0 24th February 2006 01:05 PM
Page generated in 0.09070 seconds (75.09% PHP - 24.91% MySQL) with 10 queries
