Impedence from Neutrik SpeakOn
Old 13th April 2007, 08:36 PM   #1
Nicholas1520 is offline Nicholas1520  Trinidad and Tobago
Default Impedence from Neutrik SpeakOn
If I were to use a 4 pin (2- 2+) Speakon connection right to a Behringer EP1500 for a subwooder which has 2 voice coils and it can be bridged to 8 ohms and drop to 2 ohms. But with leaving the configuration as 4 ohms on one coil and 4 ohms one the next coil will the amp give out 4 ohm power or will it give out 8 ohm power?
Old 14th April 2007, 04:16 PM   #2
R.I.P.
does the Behringer ep1500 have two channels each capable of driving 4ohm reactive loads?
If yes, then connect one voice coil to one channel and connect the other voice coil to the second channel.
send an identical mono signal to both inputs and the amp will drive both coils together and give the speaker the total power that it can drive into two 4 ohm loads.
Forget about 2ohm as I suspect the amp can only drive 2r0 resistive loads and even then only for short term loading. The heatsinks will just get too hot. But it is nice to know that the semiconductors are designed to survive the currents when cold or cool that a 2r0 load demands.
regards Andrew T.
Impedence from Neutrik SpeakOnHide this!Advertise here!
Sub plate amp with Neutrik Speakon input? D_Dubya Subwoofers 1 15th July 2009 02:02 PM
speakon to RCA help joka22 Solid State 11 15th July 2007 04:08 AM
Speakon Na4lj wotsascott Parts 3 7th July 2006 04:42 AM
Neutrik Speakon connectors timo Multi-Way 7 27th August 2002 05:47 PM
