Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Circuit Maker <<questions>>
Old 6th August 2006, 08:41 PM   #1
bogdan_borko is offline bogdan_borko  Serbia
bogdan_borko's Avatar
Default Circuit Maker <<questions>>
How to measure distortion in circuit maker 2000?
How to do Fourier analysis and measure harmonics in dB?
Old 6th August 2006, 08:59 PM   #2
I hope you understood what i`m asking for...
I meant "Harmonic distortion".
thanks
Old 6th August 2006, 09:08 PM   #3
Steven is offline Steven  Netherlands
Steven's Avatar
Default Distortion in Circuitmaker 2000
Select Analog Mode in Simulation, then go to Analyses Setup (F8), enable Transient/Fourier analysis and click on that button. In Transient and Fourier Analysis Setup enable Fourier (check box). At this moment I have the default timing selected (5 cycles, 50 points per cycle). Use a sine generator in the circuit diagram as input, e.g. at 1 kHz. Probe the output, or any point in the circuit.
Default the fourier analysis shows a linear frequency scale as the X-axis and volts or amps on the Y-axis. Right click on the Y-axis to get a pop up where you can select Primary Y-axis with Magnitude in Decibels. Then adjust the scaling, normally in the left pane, to e.g. 20dB per division and adjust the offset to get the harmonics in the graph. Distortion is calculated from the ratio of the harmonics and the fundamental.
The Analog Art shows no sign of yielding to the Dodo's fate. The emergence and maturation of monolithic processing finesse has perhaps lagged a bit behind the growth of the Binary Business. But whereas digital precision is forever bounded by bits, there is no limit excepting Universal Hiss to the ultimate accuracy and functional variety of simple analog circuits. - Barry Gilbert, 1973
Old 6th August 2006, 09:29 PM   #4
thanks a LOT!
What is a good result in these measurements?
Old 6th August 2006, 09:43 PM   #5
this is not good...?
could you comment?
it is a push pull mosfet class a power follower I`m simulating... it has no feedback, classic source follower...
Old 6th August 2006, 10:01 PM   #6
Steven's Avatar
Your harmonics are more than 60 dB below the fundamental, so distortion is approximately 0.1%, not bad for an open loop design.
Old 7th August 2006, 09:49 AM   #7
how did you calculated 0.1%?
Old 7th August 2006, 11:09 AM   #8
R.I.P.
0.1% is a thousanth = 10 to the power - 3 x 20 = - 60dB.
From the graph 2nd and 3rd dominate so I'd say ~ 0.2%.
/sreten.
Old 7th August 2006, 12:10 PM   #9
thanks a lot guys!
I`ve searched the forum but haven`t found much about
what harmonic affects the sound the most (I just now the 2nd harmonic is "good") and what harmonic should we look at when we design the amplifier...
ANy link will be helpfull.
thanx!
Old 7th August 2006, 12:17 PM   #10
R.I.P.
wieght the harmonics thus for degradation :
(harmonic number)squared / 4.
so 2nd = same, 3rd = x 9/4, 4th = x 4, 5th = x 25/4, 6th = x 9, etc
For 1khz 20 khz = x 100 or + 20dB, higher harmonics cannot be ignored......
/sreten.
Circuit Maker &lt;&lt;questions&gt;&gt;Hide this!Advertise here!
Triode spice models for Circuit maker bogdan_borko Tubes / Valves 12 20th February 2017 07:41 AM
Trying to learn Circuit maker Ryssen Everything Else 33 3rd November 2011 07:21 PM
Convert formats beteen Eagle/Circuit maker Ryssen Everything Else 0 1st August 2007 11:49 PM
circuit maker library help... Flavio88 Solid State 1 2nd September 2006 04:08 AM
Problem in Circuit Maker 2000 xitronics Everything Else 0 4th December 2005 08:04 AM
