1st attempt of 2nd order active lowpass filter failed, please advise - diyAudio
Go Back   Home > Forums > Design & Build > Software Tools
Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Old 7th February 2005, 09:42 AM   #1
SimontY is offline SimontY  United Kingdom
SimontY's Avatar
Send a message via MSN to SimontY
Question 1st attempt of 2nd order active lowpass filter failed, please advise
Hi everyone,
I tried to make a simple 12db/octave active lowpass filter, using the schematic found on WinISD - see picture attached.
However, all it gives is buzz on the output. No 'magic smoke' however.
Details:
op-amp - one side of JRC-2114 (also called NJM-2114 I think)
+ and - 13v unregulated psu (for the purposes of testing)
polyester .33uF caps and 1/4w carbon resistors, 10k
soldered on veroboard
100uF low-z psu bypass on the veroboard
Tested from CD player output (unmodified 1990s Rotel) and fed into subwoofer plate amp (RCM Acustik DT 110 MK II). (CD player direct to sub works fine)
Have I most likely made a wiring mistake? Or is this op-amp not suitable for this application? Anything sound dodgy?
I will recheck when I get home from work, and take photos as close-up as I can.
Old 7th February 2005, 09:50 AM   #2
frugal-phile(tm)
planet10's Avatar
Default Re: 1st attempt of 2nd order active lowpass filter failed, please advise
Shouldn't the input of the op-amp have a ground regerence?
Here is the map for the 2nd order subtractive i gathered parts for this evening...
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 7th February 2005, 10:54 AM   #3
Did it Himself
richie00boy's Avatar
I think your problem lies in that the non-inverting input has no DC path to ground if your CD player has a capacitor in the output (which it 99.99% will have). Place a 10k-100k resistor from your filter input point to ground.
I can't say if those op-amps are unity gain stable or not as they are not common ones. Get some proper ones from Bardwell's Also bear in mind that the unused op-amp in the package may well be doing all sorts of strange things if the inputs are not connected to anything, and it is likely to affect the used op-amp. Simply connect the unused op-amp as a unity gain buffer and ground the non-inverting input.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 7th February 2005, 10:55 AM   #4
Jennice is offline Jennice  Denmark
I trust that the OP-amp, for DC would be a voltage follower, and that the GND is just not shown. Basically, it looks like 2 LP filters in series, and then fed to a OP-amp follower/****** stage.
Nothing fancy there.
Check for (the obvious) solder-mistakes, and then check for shorted caps or resistors.
If either of the caps is shorted, you won't get meaningful signal through it.
Jennice
I get paid to break stuff. My g/f gets paid to play with children. Life is good.
Old 7th February 2005, 02:19 PM   #5
SimontY's Avatar
Thanks for the replies guys!
I suspected I'd not done enough with the ground.
This will be the first thing I try when I get home!
Firstly, Bardwell never has anything! hehe
Secondly, he probably has more stuff in stock than Maplin!
Thirdly, the op-amp is one I pulled out of my main cd player - CD63ki (a victim of 'upgrade' - to 2604).
http://www.njr.co.jp/pdf/ae/ae04028.pdf
Fourthly, I don't know what a unity gain buffer is. My understanding of electronics is 'beginner-level' at best.
Jennice, I will check for shorts carefully.
As the op-amp is just being recycled (and this is an experiment frankly, to feed my sub a 24db/oct cut-off from ~50hz) I don't mind too much if I have to buy one. The UA741 mentioned in the schematic, is that about the most common effort going?
Thanks for taking the time to help me. I'm eager to hear my sub crossed over more appropriately...
Old 7th February 2005, 02:42 PM   #6
Did it Himself
Bardwell's is OK as you as your aren't after namby pamby esoteric nonsense
I'm sure my tip with the input resistor will fix it and, if it doesn't and the assembly is OK as per Jennice's recommendation, then correctly terminating the unused op-amp will probably solve it. A unity gain buffer is simply a buffer with a gain of 1. All you need to do is connect the inverting input to output (thus 100% negative feedback) and the signal (ground in this particular case) goes to the non-inverting input. Couldn't be simpler.
A 741 will do and is 'the' generic op-amp, but I'm sure Bardwells will sell you a TL071 (single) or TL072 (dual) which will be infinitely better. An NE5534 will not be suitable in this case without an additional capacitor for compensation, but the dual version -- NE5532 -- will be fine.
Old 7th February 2005, 02:51 PM   #7
Just an additional remark:
As soon as your circuit is working you might find it a little noisy: In this case think about using smaller resistors like 10 k and use larger caps instead.
As far as your hum goes: I also expect it to come from a wiring error or ground loop (how does your DC suplly voltage look like BTW ?).
Another remark to your crossover: This is a subtractive-type crossover (which is transient-perfect or phase_accurate BTW !!) that generates a first-order highpass function by subtracting a lowpass from the input signal. This highpass has a hump due to mathematical reasons (this is NOT a hump caused by a high-Q pole, causing ringing !) that is depending on the lowpass' Q. If you use a filter of lower Q then the hump will be smaller. Many people use a Bessel 2nd-order lowpass for this reason (yours is a Butterworth one).
Charles
Old 7th February 2005, 03:04 PM   #8
SimontY's Avatar
Namby pamby esoteric nonsense? Me?
Thanks for the unity gain buffer explanation, it seems quite clear-cut. "As clear as an un-muddied lake, sir." In truth, I might get back to you on it, but only if needs be!
Interesting you should mention the NE5532 - I think the op-amp I'm using is very similar (read that somewhere). I'm sure I could still produce magic smoke, and if I do Bardwell's is 5mins drive, as I recall I told you once before
Old 7th February 2005, 03:10 PM   #9
klitgt is offline klitgt  Denmark
klitgt's Avatar
Look at this!
Everything explained very well.
http://kahuna.sdsu.edu/~tucker/diyaudio/xover.html
Old 7th February 2005, 03:14 PM   #10
SimontY's Avatar
I appreciate remarks. But did you perhaps make a mistake in saying '10k'? I am using 10k
I only plugged this thing in at 12.30am and really had to go to bed, or else I'd have multimetered things a bit more, like the output. My DC supply is about 13 volts, unregulated. I am mixing it's 'ground' with the input and output grounds. Should I be concerned by my lack of regulation? If this ever works I will add some 3-pin regulators into the mix.
I'd like to pose another electronics question in if I may. Does it matter what I 'drive' this circuit from? The signal will ultimately want to come from either the volume pot of my passive chip-amp or my Roksan Caspian pre-out (not sure which really sounds better, but I know which I can sell on Ebay!).
Active Filter for 6th order Vented Box bwhitejr Multi-Way 1 20th April 2009 05:28 PM
First-Order Lowpass Filter with a Cap Taterworks Multi-Way 6 14th October 2007 01:55 PM
4th order lowpass with one transistor AudioAngel Solid State 2 18th April 2007 05:42 PM
Active lowpass filter + high rails Firebug24k Solid State 4 19th September 2004 07:47 PM
Active lowpass filter problem Matttcattt Chip Amps 8 29th March 2004 04:24 PM
Copyright 1999-2017 diyAudio
