Eagle 9.1: buggy without alpha blending, unusable with it
Has anyone experienced the same problem ?
If I check on the "use the alpha blending" option (in the "options-set" menu) and try to route a net on the bottom that is also linked to a plane on top, I cannot see what I'm doing, as the top is highlighted and not transparent. As shown in the first attached picture.
If I disable the option, all is well... except that I've got bad display artifacts.
Any idea on how to fix this ?
