Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
LTSpice model for a commercial toroidal output transformer
Old 12th July 2018, 02:33 PM   #71
dch53 is offline dch53  Australia
Thanks very much for this. More I've learned!
However, I am unable to plot impedance. Expression is correct but still showing level and phase. I must have missed something.
Referring to your plot, it appears that Z decreases as Lcfb increases. Is that correct?
Old 12th July 2018, 02:52 PM   #72
Koonw is offline Koonw
Yes, as Lcfb increased, Nfb increased so the Ra decreased. You can insert the current source in between P-1 and P-2 to get full Ra-a. In this case there is no voltage difference between P-1 and P-2 so the block cap is not needed and gives you more accurate result.
To display impedance level in ohms, on the waveform window, right click to bring up popup manual, click on the "Manual Limits", on "Left Vertical Axis", select "Linear"
To turn off the phase plot, left click on right axis (phase) to bring up popup manual, click on "Don't Plot Phase".
Old 12th July 2018, 03:00 PM   #73
Got it. Thanks again! That is really clever. I even worked out how to add the labels.
Plot of full Ra-a attached.
Earlier you said "Since only the primary Z is measured, the speaker load 4/8 ohms should disconnected or connected for overall result."
I thought the primary Z is supposed to be 4K (in this case) WITH the 8Ω load attached. I see you have R2 set to 80K. I'm obviously misunderstanding something here.
Originally Posted by 45 View Post
So if you want to see the effect of cathode feedback and you want to use the Polish 4K transformer with CFb then you can't optmize for 4K without CBf and assume that it will be fine with CFb on! So when you run the simulation without CBf you have to use ANOTHER transformer that has got all those cathode winding turns at the plate so that the primary load is 7K. Otherwise you are comparing two amplifiers where very likely one is optimised in the way you want (for example max power with minimum distortion) and the other won't be! Instead if you compare 7K standard transformer with 4K+24% CBf the operative conditions of the output stage stay the same. The point is that 24% CFb is a lot.
Thanks. I had to read this a few times but it makes good sense.
Old 13th July 2018, 03:37 AM   #74
If the load is connected you can see overall result which the is result of both current source and load in parallel. So to measure the output impedance of secondary the load is also set to very high or disconnected.
If connected it's the overall result of both in parallel (sorry for not clarify earlier).
But the thing is that the secondary output Z measured is about 16 Ohms instead of 8, with 0H Lcfb, what gives?
PS: So if we connect 16 Ohms to secondary, and then pri Z measured again between P-1 and P-2 is 2k (half of 4k measured earlier), that is result in parallel of current source and (reflected) load.
Old 13th July 2018, 03:52 AM   #75
Ahh. It makes sense now.
What indeed! I hope you're not asking me! I'll be interested to know the answer to that.
So, you could also plot damping factor.
Old 13th July 2018, 07:32 AM   #76
Well, there is nothing wrong as it per design for now, but you can easy bring the output Z down with additional Nfb using Lcfb or Gnfb, just to be aware of the actual output Z to use for accurate measurement. I'll post the damping factor plot later.
Old 15th July 2018, 08:20 AM   #77
Default Simulation with the VDV4070CFB Transformer
Schematic is shown in the first attachment. THD vs Power is shown in the second attachment.
THD at 50W is estimated as 3%. The MOSFET screen and output anode traces in the third attachment look pretty awful!
koonw’s output stage simulation suggests 0.5% THD at 50W. Maybe this is a result of the perfect signal sources in that simulation.
THD at the MOSFET sources deteriorates rapidly after 50W output due to clipping of the negative cycles (3rd attachment). I can fix that by changing the MOSFET negative supply from -150V to -200V but that doesn't have much impact on the output stage because the 6550s are turned off then anyway.
Menno van der Veen reports 50W for this configuration but doesn’t give any THD data.
Any suggestions how I can improve the performance of the sim or the circuit?
File Type: png MOSFET Source and anode at 50W output.png (41.8 KB, 14 views)
Old 15th July 2018, 11:49 AM   #78
Try to increase K factor from 0.9995 to 0.99995, as you probably have too much leakage inductance as shown by the ringing top waveform, esp. at higher output.
Old 15th July 2018, 02:18 PM   #79
Default Leakage inductance
Thanks. That made a huge difference! THD < 1.2% up to 80W. the simulation even shows it dropping to 0.9% at 90W. Output tube dissipation at that point is still only 25W.
I'll read up on modelling the leakage inductance. I've read that toroidal transformers have lower leakage inductance than traditional EI cores. I'll also do deeper into Norman Koren's The Emperor's New Amplifier.
Old 15th July 2018, 04:57 PM   #80
euro21 is offline euro21  Hungary
Before you changing anything, look at output tube G1 waveform in the simulator.
About +30V.... -150V swing.
Then look in 6550 datasheet the UL characteristic: 0V... -70V swing.
No comment.
LTSpice model for a commercial toroidal output transformerHide this!Advertise here!
Homebrew Toroidal Output Transformer Osvaldo de Banfield Tubes / Valves 77 12th March 2017 04:00 PM
Toroidal Output Transformer FullRangeMan Tubes / Valves 11 2nd March 2011 05:10 AM
LTspice model for Dynaco A470 Output Transfomer Ray Waters Tubes / Valves 5 17th February 2011 03:33 PM
Output Tube biasing for Toroidal Output Transformer gingertube Tubes / Valves 7 17th April 2005 04:40 PM
toroidal SE output transformer noyan Parts 10 11th July 2004 10:41 PM
