Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Klippel Near Field Scanner on a Shoestring
Old 16th July 2018, 11:01 PM   #351
gedlee is offline gedlee  United States
gedlee's Avatar
Sounds like a powerful package - after my time!
Earl Geddes Gedlee Website
Old 17th July 2018, 02:26 AM   #352
mwmkravchenko is offline mwmkravchenko  Canada
Mark Kravchenko
mwmkravchenko's Avatar
Originally Posted by 3ll3d00d View Post
this is working on the impulse response rather than FRD
what format does the smith & larson software export to? no obvious manual online so hard to tell what it can do
The Smith & Larson software exports to almost every style you have mentioned. So after looking today and doing a bunch of measurements I can say you have it covered.
Mark
www.kravchenko-audio.com
Old Yesterday, 08:07 PM   #353
3ll3d00d is online now 3ll3d00d  United Kingdom
3ll3d00d's Avatar
Originally Posted by gedlee View Post
The DataOut array is not in angle, it is in modes. The first mode versus frequency, the second, etc. Hence a contour plot makes little sense. Plot it as separate frequency responses for each mode.
does this look right? The data set is the example data from your website.
Old Yesterday, 10:03 PM   #354
3ll3d00d's Avatar
I don't follow this bit
To get to a reconstructed polar plot you need to go one step further and use
Code:
Declare Function CalPolar Lib "MeasCalcs.dll" (ByRef DataIn As Complex, _
                                                     ByVal NumCoef As Integer, _
                                                     ByVal angl As Double, _
                                                     ByVal freq As Double, _
                                                     ByVal farnum As Double, _
                                                     ByVal Velnum As Double) As Complex
at this point we have
1) a set of measurements at various angles (e.g. 0, 5, 10...180)
2) a set of log spaced frequencies
3) a chosen number of modal coefficients
4) an (angle, freq) dataset (of complex numbers) via linToLog(fft(x)) where angle are those in 1) and freq from 2)
5) a (mode, freq) dataset (of complex numbers) via calSpatial where mode is a range of 1 to teh value in 3) and freq is from 2)
now we have the CalPolar function which returns a complex number given
- dataIn : is this the data from 4) or 5)? The arguments and the reference to Pressure make me think it must be 4) but in that case I don't understand what numCoefs refers to.
- numCoefs: is the same as 3) above? i.e. the no of coeffs passed into calSpatial
- angl : the angles from 1) in radians again?
- freq : the log spaced frequencies from 2)
- farnum : hardcoded to 10.0
- velnum : the !DEC$ section suggests this is SourceRadius which I guess is referring to the driver radius? i.e. the value passed to CalSpatial as "Radius"
the combination of references to coefs and angles is what confuses me as I don't understand how the two are related.
Anyway if it is the linToLog output then I call this function for every single value returned from linToLog. This output is complex so I calculate the magnitude and pass it to smooth and then I use that to feed the contour map?
If I'm right so far, I don't understand the relevance of the data from CalSpatial
I imagine this would make more sense if I understood the maths ....
Old Yesterday, 11:21 PM   #355
3ll3d00d's Avatar
attempting to call CalPower I notice that as soon as angl is non zero then the program pauses (permanently) and prints
Code:
bad arguments in sphbes
to the console
google finds some code to do with a spherical bessel function that has this output, e.g.
Numerical Recipes in C: The Art of Scientific Computing - William H. Press - Google Books
if this code is in the dll then it would be good to remove it (blowing up hard is better than hanging IMV)
in the meantime I'll try to recreate in c#
Old Today, 01:21 AM   #356
gedlee's Avatar
You have it mostly wrong.
1) are measurements, inputs.
2) Are the frequencies where we want data
LintoLog gives us the same set of measurements but now log spaced.
3)Is just a number - the number of modes used in the reconstruction, it can be anything, but 15 seems about right for us. Lower values, but finite, would be the easiest to debug.
4) you have correct, its the output of the 2) and the next line
5) Is correct as well.
Calpolar returns the dcomplex pressure at any requested "angle" and "Freq", no reference to what was actually measured. Array 5) is a "model" if you will of the speaker for all angles (in the horizontal plane) and all frequencies. It is simply now in "modal" space. Modal space completely defines the radiation pattern.
Want a very close analogy Think of electrons patterns around a nucleus. Knowing the shell numbers completely specifies the electron distribution. It's basically the exact same problem.
I already defined the other variables.
The routine is exactly the one in your reference, and it would be impossible to remove as it is key to the software. And yes, it is an antique, probably 40 years old now or more! I didn't write it and it would be very dangerous to modify it. This has never been a problem for me when the data is sent in correctly.
Your plots look OK, except for the 600 dB scale, I can't live with more than 100. But you can see the modes "cut-in". That's exactly what they do. Does your plotting have interpolation for smoother plots?
Old Today, 08:53 AM   #357
3ll3d00d's Avatar
OK thanks for the explanation.
Let me play this back to make sure I understand
(dataIn, angl, freq) is the output from linToLog
i.e. I can call CalPolar something like this
Code:
        logData, logFreqs = linToLog(measurement.fftData, measurement.fs / measurement.fftPoints)
        for ld in logData:
            for lf in logFreqs:
                print(calPolar(ld, 15, math.radians(measurement.angle), lf, 0.10, 0.15))
i.e. call linToLog for a single measurement and then call calPolar for each log spaced frequency and piece of data returned
is it correct?
If so, this does produce a pause as soon as I move onto the 5 degree measurement
in C# terms, it pauses on the following data
Code:
using System;
using System.Numerics;
using System.Runtime.InteropServices;
using System.IO;
namespace CalPower
    class Program
        static void Main(string[] args)
            Complex a1 = new Complex(0.00743564367029359, -0.0020608701139408466);
            int a2 = 14;
            double a3 = 0.08726646259971647;
            double a4 = 20.0;
            double a5 = 0.15;
            Complex output = MeasCalcs.CalPower(a1, a2, a3, a4, 0.10, a5);
            Console.WriteLine(output);
            System.Threading.Thread.Sleep(20000);
class MeasCalcs
        [DllImport("MeasCalcs.dll", CallingConvention = CallingConvention.Cdecl)]
        public static extern Complex CalPower(Complex dataIn, int numCoef, double angl, double freq, double farnum, double velnum);
So I am going wrong somewhere but I don't know where so I'd appreciate your help is debugging this.
Old Today, 08:56 AM   #358
3ll3d00d's Avatar
atm I've left it to automatically determine the range from the boundaries in the data, I can reduce this to more sensible levels though for sure. There are lots of options on how to interpolate both lines and grids for the contour plots. If there is a particular preferred method then I can look for an equivalent otherwise I can just add one later on.
Klippel Near Field Scanner on a ShoestringHide this!Advertise here!
Klippel R&D Measurement Methodology SUBduction Multi-Way 3 11th December 2016 04:37 PM
TB W3-1878 Klippel graph aarvin2 Full Range 3 18th November 2012 03:04 PM
Why doesn't DIYAUDIO have a klippel? JZatopa The Lounge 26 14th November 2011 02:40 AM
Vinyl Scanner? Nehesi Analogue Source 37 20th July 2011 08:29 AM
TD15M, does anybody have one willing to donate for Klippel testing? thadman Multi-Way 71 4th September 2009 03:10 AM
