Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Klippel Near Field Scanner on a Shoestring
Old 14th July 2018, 02:08 PM   #341
3ll3d00d is offline 3ll3d00d  United Kingdom
3ll3d00d's Avatar
completed the port to matplotlib and got a contour plot working
pics
automatically detects where to put the gates (tbd how reliable this work, works for this data)
applying the window
resulting FR
and in contour form, interval between contours and colour scheme is selectable atm
still need to sort out the labelling of the x axis
Old 14th July 2018, 08:22 PM   #342
3ll3d00d's Avatar
Originally Posted by gedlee View Post
Getting good data out of CalSpatial will be a major milestone. The DataOut should be plotted to see if it looks reasonable.
I can call CalSpatial and get results back as expected & I added UI fields for the various parameters and set them to the stated defaults.
I assumed dataIn is the output from linToLog btw
I just need to know how to plot this and what good looks like.
I'll try getting the magnitude and plotting as a contour to see what that looks like.
Old 14th July 2018, 09:09 PM   #343
3ll3d00d's Avatar
data converted to magnitude and plotted as a contour
no idea if this is correct, the process didn't explode when I called calspatial though so that gives some confidence the data is valid
Old Yesterday, 12:50 AM   #344
mwmkravchenko is offline mwmkravchenko  Canada
Mark Kravchenko
mwmkravchenko's Avatar
Mark
www.kravchenko-audio.com
Old Yesterday, 09:22 PM   #345
aslepekis is offline aslepekis  United States
Looking good!
I have to say, it's very exciting to see this progressing.
Old Yesterday, 09:26 PM   #346
3ll3d00d's Avatar
any preferences on file formats to support for importing measurement data? I was thinking
- holm (single text file)
- REW (impulse as txt)
- ARTA (pir)
- wav
- dbl
anything else?
I think all of those are trivial except ARTA which has some custom binary format so I might not get to that until I feel the need (NB: trivial means practically no thought or code required as opposed to easy)
Old Yesterday, 10:42 PM   #347
Mark Kravchenko
FRD file type.
All the Smith & Larson stuff is also quite widespread.
I could provide an example of these files if you want.
Mark
Old Today, 07:17 AM   #348
3ll3d00d's Avatar
this is working on the impulse response rather than FRD
what format does the smith & larson software export to? no obvious manual online so hard to tell what it can do
Klippel Near Field Scanner on a ShoestringHide this!Advertise here!
Klippel R&D Measurement Methodology SUBduction Multi-Way 3 11th December 2016 04:37 PM
TB W3-1878 Klippel graph aarvin2 Full Range 3 18th November 2012 03:04 PM
Why doesn't DIYAUDIO have a klippel? JZatopa The Lounge 26 14th November 2011 02:40 AM
Vinyl Scanner? Nehesi Analogue Source 37 20th July 2011 08:29 AM
TD15M, does anybody have one willing to donate for Klippel testing? thadman Multi-Way 71 4th September 2009 03:10 AM
