Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Xsim-3D development... I could use some math help
Old 24th January 2018, 03:41 AM   #21
nc535 is offline nc535
Originally Posted by bwaslo View Post
Los Angeles?
line arrays
re' which I expanded your example to 24 drivers and everything was fine; then added a driver and got access violation at address 00515BC1
Old 24th January 2018, 03:49 AM   #22
bwaslo is offline bwaslo  United States
Old guy with soldering iron
bwaslo's Avatar
line arrays... should've seen that.
Can you zip up the file (before adding the crashing step) and send or post it?
[W9MJE] Horn spreadsheet SynergyCalc/; SmallSyns SmallSyns;
Crossover design Xsim; Depot diffusor super-easy diffusors
Old 24th January 2018, 04:02 AM   #23
here you go
Old 24th January 2018, 05:14 AM   #24
bwaslo's Avatar
Havent got to your file, but wondering --is this a LA youve built? If, so great test case to compare with reality!
Old 24th January 2018, 06:00 AM   #25
AllenB is offline AllenB  Australia
the phase component
You mention you are pre-diffraction at this point. Couldn't you use an absolute distance value for phase?
Old 24th January 2018, 06:58 AM   #26
DPH is online now DPH  United States
Can you explain? I know of Sinc interpolation for connecting sample points without adding new HF data, but is there such a thing for complex values?
I probably was a little too quick to pull the trigger on my response WRT complex interpolation. In what I read as follow-up, the trend I'm noticing is that folks will split the arrays into their real and imaginary components (or polar, take your pick) and do the interpolation of the two arrays separately.
Not sure how badly that would screw up magnitudes, though.
E.g python - Interpolate whole arrays of complex numbers - Stack Overflow albeit this discussion is for Numpy, same concept.
E.g. (2) This is how Matlab's baked in interpolation does it, too http://www.mathworks.com/help/matlab...html#btw0gu1-1
Happy DIYing, Daniel
Old 24th January 2018, 12:38 PM   #27
It's the same driver as @wesayso. Spacing need to be tweked to match
Old 24th January 2018, 06:36 PM   #28
bwaslo's Avatar
E.g. (2) This is how Matlab's baked in interpolation does it, too 1-D data interpolation (table lookup) - MATLAB interp1
DPH, thanks.
Actually, I already do something like that for interpolation over frequency. I used a "constrained spline" curve fit to map from one set of frequency points to another. In the sim I always work with the same set of frequency points, so when data is read in from any-old FRD file, the first thing that happens is to map it to my working frequency list. I usually interpolate real and imaginary (separately), since that sidesteps the issue of unwrapping phase being somewhat error prone. But I guess there's no reason such an interpolation wouldn't work for points spaced geometrically. But it still doesn't solve my issue of how to combine data taken at horizontal offsets with data taken at vertical offsets.
My test case (a circular piston, where I can calculate response vs an angle "theta" relative to the disk's normal vector) lets me calculate a usable value, and also I can calculate responses from vertical and horizontal offset angles-only values separately so I can check how well various combining approaches work (ideally, the result would be the same using the overall 'theta' value.
I haven't gotten too far into it today (other matters call) but it occurred to me this morning that I should perhaps convert the measured data arrays so the they are mapped, instead of in Horizontal and Vertical angles, into something more "circularly" oriented, see diagram below -
Xsim-3D development... I could use some math help-thetaalpha-png
IOW, define an orientation in terms of the angle "Theta" (as before for circular disks) and another angle (call it "Alpha", as its one of the few Greek symbols I recognize both name and symbol for!). I don't remember the terminology for this coordinate system (is this the "spherical"?). Anyway, I'm looking at ways to combine response values in terms of these two angles.... might still not help the basic problems of how to combine. But if I use a basic interpolation between two sets on the same Theta angle (not on H and V directly), but interpolate on the Alpha angle rather than some other parameter, I should be able to get it so interpolating between two data points taken where they differ only in Alpha I can get the same complex result yields the same complex result also. I think. (This is where I would've done well to have spent more time in math classes and less in circuit theory classes )
Old 24th January 2018, 06:37 PM   #29
bwaslo's Avatar
Thanks, I'll drop wesayso a PM and see if he can send me some measured data.
Old 24th January 2018, 06:42 PM   #30
gedlee is offline gedlee  United States
gedlee's Avatar
Is there such a thing as a spline curve-fit for an array of complex values??
Sure there is, I do it all the time. All you have to do actually is to take any real interpolation algorithm and make the variables complex. In FORTRAN this is trivial, in other languages not so much since only FORTRAN has a complex data type and keeps track of all the complexities for you. The only "gotcha" is that if you ever need to multiply two complex numbers then "usually" you have to multiple one as a conjugate.
I have a FORTRAN routine that will do this that I could send you.
Earl Geddes Gedlee Website
Xsim-3D development... I could use some math helpHide this!Advertise here!
XSim help awkwardbydesign Multi-Way 23 8th March 2017 12:27 PM
Looking for someone to teach me xsim Bill poster Software Tools 1 10th January 2017 10:51 PM
XSim - Crossover Lab for Newbies eriksquires Software Tools 3 11th November 2016 03:53 PM
Xsim crossover critique montana1 Multi-Way 46 22nd February 2016 07:38 PM
XSim: 3rd and 4th order blocks? eriksquires Multi-Way 10 13th January 2016 06:38 AM
