Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Xsim-3D development... I could use some math help
Old 23rd January 2018, 10:18 PM   #11
bwaslo is offline bwaslo  United States
Old guy with soldering iron
bwaslo's Avatar
Is there such a thing as a spline curve-fit for an array of complex values??
[W9MJE] Horn spreadsheet SynergyCalc/; SmallSyns SmallSyns;
Crossover design Xsim; Depot diffusor super-easy diffusors
Old 23rd January 2018, 10:25 PM   #12
DPH is offline DPH  United States
Sinc interpolation?
Happy DIYing, Daniel
Old 23rd January 2018, 10:28 PM   #13
bwaslo's Avatar
Thinking out loud, here.... Maybe do some sort of weighted average (weight by cosines of the H and V angles?) of Mag/angle formatted values, with the angles first unwrapped?
4D stuff (x,y,z and time/frequency) gets nasty to deal with pretty quickly!
Old 23rd January 2018, 10:31 PM   #14
bwaslo's Avatar
Originally Posted by DPH View Post
Sinc interpolation?
Can you explain? I know of Sinc interpolation for connecting sample points without adding new HF data, but is there such a thing for complex values?
Old 23rd January 2018, 10:41 PM   #15
bolserst is offline bolserst  United States
bolserst's Avatar
Originally Posted by bwaslo View Post
...Otherwise, all my clever off-axis and boundary reflection simulations won't work with anything other than radiating round pistons...
You could expand to include ribbons and ESLs without too much effort, using rectangular piston directivity.
I have found the attached formula to match well with measurements and brute force distributed point summation calculations.
With vertical angle set to 0, the horizontal directivity is that of a line source(ie sinc function) with line length = piston width, similar in the vertical direction using line length=piston height. This formula may provide some ideas of how to approach combining disparate H & V directivities. I'm still cogitating on it...
BTW, the rectangular piston formula in Beranek Acoustics is just the product of the horizontal and vertical line source directivities and does not match as well.
Old 23rd January 2018, 10:59 PM   #16
bwaslo's Avatar
Isn't the attached equation the same thing? (product of the horizontal and vertical line source directivities). I don't have the Beranek reference you mention..
Old 23rd January 2018, 11:08 PM   #17
bolserst's Avatar
The attached Beranek equation uses horizontal width(d1) and horizontal angle(theta1) to calculate the horizontal line directivity, d2 and theta2 for vertical line directivity and then multiplies them together.
The previous equation uses angle theta as angle relative to the piston normal, and phi as projected angle relative to the x-axis.(ie if vertical angle = 0 and then phi = 0deg, if horizontal angle = 0 then phi = 90deg)
File Type: png Rectangular_Piston_Directivity_Beranek.png (10.8 KB, 123 views)
Old 23rd January 2018, 11:13 PM   #18
bwaslo's Avatar
bolserst -- thanks. Got it (I think).
Old 23rd January 2018, 11:15 PM   #19
bwaslo's Avatar
I meant the angles of the complex result (arrayed by frequency) being "phase unwrapped". To avoid the issue of periodicity of phase values. I'll play with that a bit, see if there's any hope for that.
Old 24th January 2018, 12:59 AM   #20
bwaslo's Avatar
Another thought -- maybe to interpolate on group delay (with polarity) for the phase component? Or phase delay (from unwrapped frequency starting at 0 or 180degree at LF)?
I'll have to hack into the code and do somethings in different order to even try such things -- I currently do each frequency separately and combine, but to get these, I'd have to go through all frequencies per driver (and per reflection!) first do then get delay or unwrapped phase. Messy, but I don't want to give up, at least not yet.
Xsim-3D development... I could use some math helpHide this!Advertise here!
XSim help awkwardbydesign Multi-Way 23 8th March 2017 12:27 PM
Looking for someone to teach me xsim Bill poster Software Tools 1 10th January 2017 10:51 PM
XSim - Crossover Lab for Newbies eriksquires Software Tools 3 11th November 2016 03:53 PM
Xsim crossover critique montana1 Multi-Way 46 22nd February 2016 07:38 PM
XSim: 3rd and 4th order blocks? eriksquires Multi-Way 10 13th January 2016 06:38 AM
