Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Testing software different results
Old 10th January 2018, 04:58 PM   #1
wicked1 is offline wicked1  United States
wicked1's Avatar
Default Testing software different results
I'm testing an amplifier and have a couple questions.
In Arta, I can test the frequency w/ the main frequency testing button (FR1).
Or, I can record an impulse and analyze that. (Record Impulse, then I press F12)
The results are different. Bass rolls off sooner w/ the impulse.
Which should I use?
Also, I get different results in different software. My amp measures better in both frequency response and distortion in AudioTester than in Arta.....
Is that normal?
Thank you.
Old 10th January 2018, 05:24 PM   #2
Pano is online now Pano  United States
Pano's Avatar
Quick question - does a loop test of your soundcard also give you different results?
I would assume so, but it's best to check.
Take the Speaker Voltage Test!
Old 10th January 2018, 06:31 PM   #3
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Which should I use?
Is that normal?
Thank you.
Are you using the same soundcard in the two cases?
Jan
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 10th January 2018, 06:58 PM   #4
wicked1's Avatar
Yes. Same sound card. It's just my built in sound card on a cheap motherboard, so overall it's not great. But these results are consistent.
As far as the differences between the two softwares, I think maybe AudioTester is smoothing/filtering the signal more than Arta.
I'm still curious why the frequency test (fr1) in arta is different from the impulse response being converted to a frequency response.
Maybe it's my amp reacting differently to the impulse vs the other frequency test.. But which do most people use when they record and post charts of their frequency response?
Old 10th January 2018, 07:41 PM   #5
wicked1's Avatar
Hmm, for imp vs fr1 in arta, they are close to the same w/ a loop.
Arta vs AudioTester are different. I haven't looked at the settings much in audiotester yet, but like I said in my last message, I think it's simply filtering the input or smoothing the results more.
I think my questions are answered at this point.
Thanks!
Old 15th January 2018, 07:31 AM   #6
bwaslo is offline bwaslo  United States
Old guy with soldering iron
bwaslo's Avatar
On something like an amp, smoothing should make little or no differences -- there aren't sharp resonances like you'd have in a loudspeaker.
If your amp reacts differently to an impulse than to a sine sweep or spot test, then your amp isn't linear!! I doubt that's the case. Are you watching your level with the impulse response test? It's easy to overdrive an amp with an impulse since it has very high peak level compared to it's nearly zero output energy.... usually, if the impulse is clearly audible, something is likely getting overloaded.
[W9MJE] Horn spreadsheet SynergyCalc/; SmallSyns SmallSyns;
Crossover design Xsim; Depot diffusor super-easy diffusors
Old 17th January 2018, 11:31 AM   #7
Svein_B is offline Svein_B  Norway
I have always used Arta, IMP mode with sweep tone.
Has always given consistent and reliable results, provided you observe the volume level.
SB.
Testing software different resultsHide this!Advertise here!
TRANSFORMER TESTING RESULTS LATUBEGEEK Instruments and Amps 5 14th August 2013 01:10 PM
Driver testing results augerpro Multi-Way 77 23rd July 2009 10:50 PM
What testing software should I use? TurboFC3S Multi-Way 5 2nd October 2006 09:46 PM
New Software For Testing jwatts Multi-Way 2 5th November 2004 09:26 PM
