Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Help, can I use VituixCAD to merge simulated driver measurements
Old 3rd January 2018, 10:35 AM   #1
Jeremy067390 is offline Jeremy067390
Default Help, can I use VituixCAD to merge simulated driver measurements
Iím following the simulated measurements guide off Undefinition, usually it works off response modeler but Iím waiting on a copy of excel so I found VituixCAD. So Iíve used vituix to trace my factory graph. I used vituix and WinISD to model my drivers in a box (near identical results btw). I now need to use merge to combine the two to get my simulated frd. So far these are my results. The first chart is the modeled drivers with the factory chart. The second is the modeled drivers with the factory chart for 2 drivers. Are either of these correct?
File Type: jpg 25EDE8D2-7049-426E-8116-92DE8C5A1BF7.jpg (201.6 KB, 59 views)
File Type: jpg 4EADAB5D-478F-4EEA-BFF9-6C6138B1A423.jpg (202.4 KB, 60 views)
Old 3rd January 2018, 12:11 PM   #2
kimmosto is offline kimmosto  Finland
Both factory graph and box+driver simulation look like half space responses. If so, merging of these curves (and nothing else) is okay if you are making flush mounted speakers. But if your speakers will be typical box speakers, you need to make baffle simulation with Diffraction tool and export response. After that you can multiply merged half space response by exported diffraction response and scale the result response by -6 dB with Calculator tool. VituixCAD supports few other methods too.
Sorry that my answer is quite truncated but I have fever.
Old 3rd January 2018, 02:51 PM   #3
Thanks that is what I’ll do. Can I ask which of these half space responses are the correct one to use.
Old 3rd January 2018, 06:15 PM   #4
Select that one which has correct SPL in your application: if you have two drivers in parallel, select traced curve having higher SPL. Then you should adjust level offset of simulated curve to match SPL with traced curve. Reality and simulation have some differences here.
I would also increase transition frequency to e.g. 500 Hz to get more realistic phase response. Now there is too sharp corner in phase because simulated system is ported and traced is big closed or IB.
Old 3rd January 2018, 07:21 PM   #5
Awesome. Thank you for all the help you provide us
Old 4th January 2018, 04:10 AM   #6
One more thing. I'm not sure where and how you are using those responses. If you load them into crossover simulator where you connect two separate drivers in parallel or series, you should use frequency and impedance responses of single driver (with lower SPL and higher impedance) because crossover simulator calculates terminal voltages and sums acoustical signals.
From my point of view it is more common that all responses are measured or simulated from a single driver (if technically possible), and crossover simulator takes care of the rest. That also enables adjusting of directivity and power response with driver locations in case measurement set includes off-axis responses (0-90/180 deg). I suppose "guide of Undefinition" is some coarse pre-engineering style - not so advanced what VituixCAD is designed for.
Help, can I use VituixCAD to merge simulated driver measurementsHide this!Advertise here!
VituixCAD diypass Software Tools 427 Yesterday 08:40 AM
MA driver measurements tuxedocivic Full Range 67 13th April 2014 11:55 PM
How can I merge ... dflippo The Lounge 1 14th June 2013 01:36 AM
Software to merge near + far field measurements jgv Multi-Way 3 25th April 2012 04:06 PM
Driver measurements Legis Multi-Way 0 12th October 2010 06:08 PM
